    Oct 2012
    Default Dual Shield welding help!!
    I've ran Dual Sheild wire in my 12vs powered by a Trailblazer 302 and it ran great. I just bought an older Millermatic 251MP and it doesn't seem to like it much. I tried to set the wire on the machine as .045 Steel and .045 fluxcore and it just does not like it. Does anyone have any tips for me to get this working with this machine? Thanks....
    Apr 2012
    Western Pa.
    333
    What shielding gas are u using?
    Was having some problems at lower settings but ran good at higher voltage ie. spray transfer.
    I switched from 75/25 gas to 85/15 and ran better all way around especially at lower settings. Just a thought. (using 350-p)
    8,350
    Thats a 250MP, not a 251, and the problem is that the 250 doesn't have the wire speed to run dual shield. Mild steel is fine on it though.
    Oct 2012
    I'm using CO2...
    You are correct, 250MP. I did the unthinkable and downloaded Millers iPhone app for welding setting - It actually worked - I was running 145 ipm and I needed to be at 210-230. It works great now! Also - I took my machine up to it's highest ipm setting - 670 is where it stopped, I think I have enough! Thanks guys and sorry for the brain fart!
