First time poster and newb to welding. Just interested in hobby welding around the shop. I want to make a welding cart and some rolling stands for machinery. No cars.
I bought a Thunderbolt 225 at an auction a couple of years ago but have not used it yet. I have recently run 220 to my garage. I also recently bought a Millermatic 211.
Now, I have a small garage and need all the extra room I can get. My question is: will the 211 do everything that the Thunderbolt will do? Can I get rid of the Thunderbolt?
I have heard "If its thick, use stick" but I don't know if my little Thunderbolt is big enough to make a difference.
Results 1 to 10 of 39
Thread: 211 and/or a Thunderbolt 225
10-09-2012, 11:49 AM #1
- Oct 2012
- 47
10-09-2012, 01:42 PM #2
The MM211 will do 99.9% of everything a Hobby welder will need done.
I've built quite a few things w/o having a Stick welder- before we even purchased the MM252 I used a 120v machine, then a Passport. Don't really need the 252, probably should have just purchased a MM212.
I'm really a hobby welder that has been able to build stuff for my work/business but welding is not any part of the business.
For me:
Wire feeder like the MM211 or equivalent is a workhorse. Fast & Clean, sheet metal to 1/4", some 3/8".
I would sell the Thunderbolt and buy more hand tools: Port-a-band, Chop saw, Hand grinders, Clamps.
I put off the Port-a-band for way too long.
I highly recommend one. Quiet, no mess like with an abrasive chop saw. I can get pretty good 45˚ with one.
2- grinders; One with a cut off wheel and one for Flap Discs.
C- Clamps: can't have too many clamps.Ed Conley
10-09-2012, 02:39 PM #3
- Apr 2010
- 150
Save up and get a dinky inverter stick/TIG welder to complement the 211.
10-09-2012, 03:45 PM #4
- Oct 2012
- 47
Thanks Ed.
10-09-2012, 03:47 PM #5
- Oct 2012
- 47
10-09-2012, 04:06 PM #6
10-09-2012, 04:07 PM #7
here is a current thread on Grinders, save you some time since it is pretty well covered on brand, cost etc etc
http://www.hobartwelders.com/weldtal...45371-grindersEd Conley
10-09-2012, 06:34 PM #8
- Oct 2006
- Illinois
- 474
Is the thunderbolt AC/DC ? you could always keep it and get a tig set up for
it.
10-09-2012, 07:31 PM #9
- Jun 2009
- greenfield new hampshire
- 783
what is so wrong with keeping the thunderbolt, you will not get too much for it and really, how much space does it take up, learning to stick weld will be a great asset in your welding ventures, right now you have the perfect set up for just starting out, keep the buzz box, it will come in handy some time
10-10-2012, 05:39 AM #10
- Oct 2012
- 47
Thanks for the replies.
This one is AC only. It is an older, horizontal unit. Not like the ones shown in the owner's manuals here.
I was thinking the same thing Kevin. Is there anything a stick can do that a mig cannot? Like welding cast iron or some other specialty metals? I would hate to get rid of it only to find I could use it later with just some new rods.Last edited by Frank R; 10-10-2012 at 05:52 AM.
Of course you'll want more, need... well that's up to you and the Mrs.
