Results 1 to 3 of 3
    Sep 2012
    9
    Default opinions on my weld
    Stainless outside corner beside obvious end pieces which were due to improper clamping
    Jun 2012
    Tracy, CA
    215
    Nice. What's the back side look like?
    Trailblazer® 302 Air Pak™
    Miller Dynasty® 350
    Millermatic 350P Aluminum
    Millermatic® 252
    Syncrowave 351
    SuitCase® X-TREME™ 12VS
    Multimatic™ 200
    Millermatic® 211 Auto-Set™ w/MVP™
    XR-Aluma Pro Gun
    Diversion™ 180
    Spectrum® 625 X-TREME™
    Victor Oxy/Acetylene Set
    Sep 2012
    9
    small amounts of weld went through wasnt purging the weld
