Results 11 to 14 of 14
    Jun 2012
    Tracy, CA
    175
    Is there one specifically with the air-pak cut out?
    Trailblazer® 302 Air Pak™
    Miller Dynasty® 350
    Millermatic® 252
    Syncrowave 351
    SuitCase® X-TREME™ 12VS
    Millermatic® 211 Auto-Set™ w/MVP™
    Spoolmate™ 100 Series
    Diversion™ 180
    Spectrum® 625 X-TREME™
    Jun 2012
    McHenry, Il
    23
    Default Can not run this horse with any cover
    Is there one specifically with the air-pak cut out?[/QUOTE]
    When not in use and cool, cover it.
    Miller sells a cover for $140.
    Just Jim
    6,750
    There is just not enough airpacks around to justify making a cover for one, as for Miller covers, giver. You have to remove it when the machine is in use, and its not insulated. At -30 thats all I want to do is get up on my rig and remove the snow, remove the now hard Miller cover, then hope to heck that it starts. End of shft, brush the snow snd moisture off the machine, and close it up with that cover. And hope that it doesn't freeze to the machine for the next day.
    With a 50 wt pan heater under the engine (on a TB, and other) plus an insulated cover, that engine and generator is warm. Open the front flap and start it up. Weld away, end of shift, close the front flap, go home.
    asheville n.c.
    595
    love to run one about 27-28 volts all day
