I've been watching you tube videos lately, and seen welding school shops and in their booths they had posts with a small steel table and then adjustable arms to move to where you like. I know the generally jist of them. I would like to fab one up for myself to work on vertical welding and to try overhead. But I don't know how to make the clamping mechanism to hold the steel. And to be able to hold metal for butt welds fillets and others, I have not seen one up close, so I would like to know how they clamp the metal so i can make one of my own, any help or pictures would be great! Thanks for your time!
Results 1 to 4 of 4
10-07-2012, 09:47 PM #1
how to make welding stand for coupons?
10-11-2012, 03:13 PM #2
The ones I've seen lately just have a spring-clamp that is welded to the arm.
Some of them use "C" Clamps on the arm.Trailblazer® 302 Air Pak™
Miller Dynasty® 350
Millermatic® 252
Syncrowave 351
SuitCase® X-TREME™ 12VS
Millermatic® 211 Auto-Set™ w/MVP™
Spoolmate™ 100 Series
Diversion™ 180
Spectrum® 625 X-TREME™
10-13-2012, 05:52 PM #3
Member
- Mar 2006
- northwest Pa
- 76
Just tack some bars together to suit ur needs
12-09-2012, 08:33 PM #4
- Nov 2012
- 4
The ones we use have the table top that's adjustable in height and also another sleeve over the center pipe with a piece of pipe attached. Tack your coupons to the pipe and use the table to steady yourself for overhead practice.
