Results 1 to 4 of 4
    Feb 2012
    23
    Default how to make welding stand for coupons?
    I've been watching you tube videos lately, and seen welding school shops and in their booths they had posts with a small steel table and then adjustable arms to move to where you like. I know the generally jist of them. I would like to fab one up for myself to work on vertical welding and to try overhead. But I don't know how to make the clamping mechanism to hold the steel. And to be able to hold metal for butt welds fillets and others, I have not seen one up close, so I would like to know how they clamp the metal so i can make one of my own, any help or pictures would be great! Thanks for your time!
    Jun 2012
    Tracy, CA
    215
    The ones I've seen lately just have a spring-clamp that is welded to the arm.
    Some of them use "C" Clamps on the arm.
    Trailblazer® 302 Air Pak™
    Miller Dynasty® 350
    Millermatic 350P Aluminum
    Millermatic® 252
    Syncrowave 351
    SuitCase® X-TREME™ 12VS
    Multimatic™ 200
    Millermatic® 211 Auto-Set™ w/MVP™
    XR-Aluma Pro Gun
    Diversion™ 180
    Spectrum® 625 X-TREME™
    Victor Oxy/Acetylene Set
    Mar 2006
    northwest Pa
    79
    Just tack some bars together to suit ur needs
    Nov 2012
    4
    The ones we use have the table top that's adjustable in height and also another sleeve over the center pipe with a piece of pipe attached. Tack your coupons to the pipe and use the table to steady yourself for overhead practice.
