    23
    Default how to make welding stand for coupons?
    I've been watching you tube videos lately, and seen welding school shops and in their booths they had posts with a small steel table and then adjustable arms to move to where you like. I know the generally jist of them. I would like to fab one up for myself to work on vertical welding and to try overhead. But I don't know how to make the clamping mechanism to hold the steel. And to be able to hold metal for butt welds fillets and others, I have not seen one up close, so I would like to know how they clamp the metal so i can make one of my own, any help or pictures would be great! Thanks for your time!
    Jun 2012
    Tracy, CA
    218
    The ones I've seen lately just have a spring-clamp that is welded to the arm.
    Some of them use "C" Clamps on the arm.
    Trailblazer® 302 Air Pak™
    Miller Dynasty® 350
    Millermatic 350P Aluminum
    Millermatic® 252
    Syncrowave 351
    SuitCase® X-TREME™ 12VS
    Multimatic™ 200
    Millermatic® 211 Auto-Set™ w/MVP™
    XR-Aluma Pro Gun
    Diversion™ 180
    Spectrum® 625 X-TREME™
    Victor Oxy/Acetylene Set
    northwest Pa
    79
    Just tack some bars together to suit ur needs
    Nov 2012
    4
    The ones we use have the table top that's adjustable in height and also another sleeve over the center pipe with a piece of pipe attached. Tack your coupons to the pipe and use the table to steady yourself for overhead practice.
