Is there a way to safely weld with a pacemaker,my older friend is needing a pacemaker and he is not wanting to get because he will not be able to weld anymore. thanks for any inputs...!!!!!!!
Results 1 to 5 of 5
Thread: welding with a pacemaker
Hybrid View
10-07-2012, 08:13 AM #1
- Oct 2012
- 2
10-07-2012, 08:48 AM #2
Used to be alot of EM interference, though now adays with cored weld cables like Seoprene and Excelene, actual em interferance is somewhat reduced to near zero.
So other than a non inverter continous HF on tig buzzing away, welding shouldn't be a problem.
10-07-2012, 08:53 AM #3
- Oct 2012
- 2
10-07-2012, 01:55 PM #4
- May 2009
- Central North Carolina
- 133
By all means do the reading first. Google should find what you are looking for, but don't forget to have a good talk with the heart doctor, but he will likely be over protective. Find out from him which pace maker will be used and then contact the manufacturer. They will be the best source of information. You only have one heart and if the pace maker is affected it may kill you. The high frequency from doing TIG work is what you will need to be the most concerned about. Avoiding any chance of getting shocked will be a good idea too.
Charley______________________________
Miller MM252
Miller Bobcat 225NT
Miller DialArc HF & DIY Cooler
2 Miller Digital Elite and 3 Fixed Shade Helmets
2 O/A torch sets
DeWalt 18 volt 1/2" Driver/Drill
DeWalt 18 volt 6 1/2" Metal Saw
DeWalt Porta Band & SWAG Offroad V3 Table
Milwaukee 8" Dry Cut Saw
Milwaukee 14" Dry Cut Chop Saw / Delta Stand
Milwaukee 9" Grinder
2 Milwaukee 4 1/2" Grinders
Milwaukee Hole Hawg 1/2" Drill
Wallace 5 Ton Gantry
Too many hand tools
10-07-2012, 07:11 PM #5
Member
- Nov 2006
- Wetaskiwin, Alberta
- 92
A no-no
A friend of mine had a pacemaker put in this year. I was waiting for her in the recovery room. The advice she received from the person who was the pacemaker specialist was definitely not to be around any welding operations.
Another individual that I personally know also had to give up his welder testing job because of having a pacemaker put in. He was at a church when he first got it put in and was having a difficult time for the next few days because he was too close to the sound system set-up.
I think that he needs to check it out very thoroughly if he is going to continue welding.
Byron
