Anybody have one of these Harbor Freight presses? Are they worth buying instead of building one? They look super simple to fab up, didn't check on materials price yet. THANKS!
Results 1 to 7 of 7
Thread: Shop press
10-06-2012, 03:00 PM #1
Shop press
10-06-2012, 03:27 PM #2
- Sep 2005
- WY...armpit of U.S.A.
- 636
For the money, they aren't bad. Again, for the money, grab an air/over hydraulic jack in the proper size to replace the manual jack. As I said, for the money they are okay, but you may wish to rebuild sections of the press to add some tolerences to the action, otherwise the press is on the sloppy side unless the table can be clamped totally stationary. Those presses are far from precise, but for the money and the time it would take to gather, cut and weld up a better quality unit it may be the best available option.
BTW, the base, if you can call it that, is by far the weakest link on the entire press. I've replaced the base on mine with some rectangular box beam and casters. Doesn't help in the least as far as the presses action goes, but it does make it easier to move around the shop and not have to worry about the press tipping over when you are working with it.Miller 251...sold the spoolgun to DiverBill.
Miller DialArc 250
Lincoln PrecisionTig 275
Hypertherm 900 plasma cutter
Jet 14 X 40 lathe...ditto
Logan 7" shaper
Ellis 3000 band saw
Lots of dust bunnies
10-06-2012, 08:18 PM #3
- Oct 2006
- Illinois
- 458
I agree with WyoRoy. I bought 20 ton for 150.00 with coupon. I made a break for it and it does what I need. I have no problem bending 1/4''x 4'' flat stock.
Worked great to straighten bend 36'' pipe wrench handle too. At the time I
couldnot buy material for that money plus the time.
10-13-2012, 05:49 PM #4
- Mar 2006
- northwest Pa
- 76
not bad for the money. I beefed up mine and made a brake. Works great, no problem on 1/4" plate
10-29-2012, 01:35 PM #5
- May 2007
- Lebanon, Oregon
- 29
I agree with Roy 100%. I also changed mine over to air over hydraulic 2 years ago and still ask myself why I didn't do it earlier.
Hey Roy, .... that spool gun is still running great.
Bill
Miller Dialarc 250 AC/DC
Miller 251
Thermodynamics Plasma arc
Benard "Center Fire" wirefeed gun
Miller alum. spool gun
Tweco Tig torch
Victor O/A torches
B&D Wildcat 9" grinder
DeWalt 10 amp 4-1/2" grinders
7"x12" bandsaw
A shop that's always going to be to small.
10-29-2012, 07:06 PM #6
- Sep 2005
- 636
Miller DialArc 250
Logan 7" shaper
Ellis 3000 band saw
10-29-2012, 07:44 PM #7
Shop press
Ray C & BD1- how exactly did you set up your brake from the press? Premade die tooling?
Thanks,
Doug
