    Oct 2012
    Default syncrowave 180 SD
    Can anybody tell me if there is a pulse unit I could put on or use with my syncrowave 180 SD ???
    6,755
    Waste of time, do what everyone else does and pulse your peddle
    Aug 2008
    Orange, TX
    1,052
    If you need finer, more precise/consistant control than manual peddle manipulation - Miller PC-300.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    Cave Creek Az
    797
    I don't know that I would spend a lot of money on a SD180 (I have one), they are a little light on amps, and prone to break down and be expensive to fix.
