Page 1 of 3 123 LastLast
Results 1 to 10 of 29
    Oct 2012
    3
    Default New need a welder
    Just got a qoute on some steel post I want for a barn. Steel would be around 2000 and the labor 10,000. Good excuse to finally buy a welder. So this would probably by the biggest job I would ever need a welder for. It would consist of 8 post of 5X5 3/8 HSS tubing with a 3/4" base plate. I would also like the ability to weld alumium and stainless steel. What would your recomendation be.
    Jun 2012
    Tracy, CA
    175
    Just don't buy a 110v machine.
    Trailblazer® 302 Air Pak™
    Miller Dynasty® 350
    Millermatic® 252
    Syncrowave 351
    SuitCase® X-TREME™ 12VS
    Millermatic® 211 Auto-Set™ w/MVP™
    Spoolmate™ 100 Series
    Diversion™ 180
    Spectrum® 625 X-TREME™
    I think the machine I have is perfect for that job. It's the 211 Autoset.
    http://www.millerwelds.com/products/...p?model=M00245
    With a self shielded wire you'd be fine building your structure outdoors. Once you had the building up and you could get indoors you can set up the machine for both aluminium and stainless. Aluminum would require an optional gun and both would require a shield gas, so put up your buliding first. The machine requires 25A @ 220V using a 6-50 connection. It will run on 110 but not nearly as well.
    2,636
    3/8" is max for the MM211 and would probably stress the little machine on the Barn project as well as hitting duty cycle quickly.
    best bang for the $ is the Hobart Ironman 230
    $2000.00 includes shipping and 20' Spool gun
    http://www.northerntool.com/shop/too...=%7Bkeyword%7D
    2,636
    on the Barn project you'll hit the duty cycle way too soon.
    Look at the Hobart Ironman 230 with spoolgun at Northern Tool.
    I'd include a link but the post gets delayed because of the link
    The HSS is 3/8".
    That means a 3/8" fillet to the 3/4" plate if I am reading that correctly.
    And either 3/8" fillets or grooves between HSS pieces.
    There won't be any 3/4" welds.
    Not that I even believe in those thickness ratings anyway.
    Steel is steel. If you need more weld you run more passes.
    The only rating that matters is amperage and duty cycle.
    Thickness is irrelevant.
    The OP says this is the biggest task by far that he'll ever use it for and since he needed an excuse to buy a welder I think it's safe to say this building is not a paying job so it won't be go-go-go-go-go! Rather something he will do in spare time. The duty cycle will likely be fine too as long as he runs it on 220, uses small wire and doesn't treat the task as thought he's being paid by the inch.
    I've built bigger stuff with smaller equipment and it's still standing. The 211 is plenty big enough.
    6,755
    Since you apparently don't really need a welder machine for the long run, why don't you just rent say a 300 amp engine drive
    561
    I'd get a Syncrowave 200. SMAW the tube and now you have a welder for tig welding aluminum and stainless steel later. Down side is its not portable. I'd rather stick weld with a low amp welder than mig with low amp welder. Just my .02
    Kevin
    Wa
    321
    Have you ever welded before? We need to know your skill level to give any advice.
    Agreed with the 211.I only hit my temp overload after a 6' fillet weld on 3/16 using 035. New with full tank ran me $1,100. Spool gun works pretty good too. I'm definitely envious of your project! Good luck!
