Results 1 to 10 of 11
    Oct 2012
    6
    Default millermatic 250 problem
    howdy from north ga. i have a millermatic250 i bought new & used around the shop on hotrods & farm equip. i started to use it this week & it is acting up.
    i had to replace the "sheath" that the solid wire runs thu. wire was kinking
    up at times and could not get voltage to regulate. acts like a stick welder does
    when the amperage is turned up WAY WAY to high. it will arc but not matter what i try it is so hot i cannot weld with it. i tried adjusting gas flow,wrte speed
    and voltage but cannot change the situation. i pulled side off to b sure a mouse or dirt-dobber had not got inside. everything appears to be intact-not wires off or
    signs of problems. any help would be appreciated. retired power co mechanic,
    used several welders during the years but love my miller. reccomend them to all my buds. thanks BILL
    Oct 2004
    Edmonton, Alberta
    8,334
    IS gas going through, I think you have a failed gun
    Jun 2012
    Tracy, CA
    221
    I had a similar symptoms a few weeks ago. Turned out someone put a new spool of wire on and they loaded it so it was feeding from the top. After I put the spool on right it fed like a charm. Imagine that.
    Lincoln Vantage 400
    Trailblazer® 302 Air Pak™
    Miller Dynasty® 350
    Millermatic 350P Aluminum
    Millermatic® 252
    Syncrowave 351
    Lincoln LN-25 Pro
    Multimatic™ 200
    XR-Aluma Pro Gun
    Diversion™ 180
    Spectrum® 625 X-TREME™
    Victor Oxy/Acetylene Set
    Oct 2012
    6
    u can hear gas at the nozzle when u pull trigger. wire is rolling off from the bottom. guage flucuates when trigger is pulled so i'm pretty sure it's working.
    Oct 2004
    Edmonton, Alberta
    8,334
    I have a sneeking suspicion that the gas liner in the gun is busted, and your pulling atmospheric into it, to get the welds that your talking about,
    Oct 2012
    6
    Default problem
    i assume you are talking about where the wire comes out of the gun/ i had a new one installed yesterday. i also thougt my wire might be too contaminated as it
    has been in machine long time. roll i started with was "spotty" had little places
    that looked like rust. put brand new roll of wire in today but no change. thanks
    tribble
    Oct 2012
    6
    i had a new liner put in yesterday. also put new roll of wirein. u can hear gas when u put gun close and pull the trigger. guage flucuates when u pull trigger also
    Oct 2004
    Edmonton, Alberta
    8,334
    OK, lets get is straight, your wire speed controls the amperage. You replaced the gun liner (not a sheath). The gun is what the 12' cable is. I'm unsure exactly what your doing.
    Now the 250 uses a couple of SCRs for a rectifier.
    One may be damaged.
    I'd suggest you take the machine in for service.
    Oct 2012
    6
    Default 250 problem
    sorry my canadian friend but i dont know what u are talking about. my machine has a wire speed adjustment and a voltage adjustment. neither has any effect
    on the problem i am having.
    Oct 2004
    Edmonton, Alberta
    8,334
    OK, the wire has a voltage range, for 035 wire, its anywhere from18 to 22 volts.
    Wire speed controls both the wire comming out and the actual amperage.
    Now 035 needs 185 amps to weld properly
    If you had a volt meter we could easily see what was going on. With the wire drive flipped open so it doesn't feed, and your volt meter probs on the neg and the positive terminals on the machine.
    Measure from the lowest setting to the highest setting with your trigger depressed.
