I have a Bobcat Three Phase with a Kohler CH20s engine. I am having an issue where the motor is running way too fast. I have gone through the steps of adjusting the governor and adjusting the run speed as prescribed in the manual with no success. I can manual move the governor arm over and drop the rpms to acceptable levels but it does not move on its on. My thoughts are it may be the internal portion of the governor that is not operational.
However, in the run-idle position, the motors does not come down to idle position without manually moving the governor arm.
Its running at such a high speed it has melted the wire going to the large R2 resistor mounted on the upright.
Any trouble shooting ideas before I tear into the motor?
Results 1 to 10 of 12
10-04-2012, 07:35 AM #1
- Oct 2012
- 17
Miller Bobcat Three Phase Motor Run Speed Issues
10-04-2012, 08:00 AM #2
Did you not adjust the adjuster arm left of the exhaust, with the 3/8" nut and lock nut. Or did you move the govenor spring which is definately a no, no...
10-04-2012, 08:30 AM #3
- Oct 2012
- 17
10-04-2012, 09:22 AM #4
OK, I guess you'll have to remove the engine. Engine removal for you should take all day
10-04-2012, 02:15 PM #5
- Oct 2012
- 17
Thanks for the info. I'm a little confused on one part. I'm unsure if the shaft is threaded or not. My serial number is LE114xxx. Is there a range of serial numbers where the shaft is tapered and will pop off as you describe?
The below link suggests that from Serial No. LE294171 to present it is a threaded shaft.
http://www.mymowerparts.com/pdf/Kohl.../353938134.pdf
The owners manual for my Serial number range appears to show a threaded shaft. Is there an easy way to identify the shaft type before I start. I don't want to be prying on the stator housing to hard trying to pop it off, if its a threaded shaft.
10-04-2012, 02:27 PM #6
I suppose you could be correct, the TB and such just pop off, apparently yours doesn't, so lucky you! Thats alotta work!
10-05-2012, 10:06 AM #7
- Oct 2012
- 17
Does anyone know the range of serial numbers where the Kohler shaft is tapered or threaded?
10-05-2012, 06:53 PM #8
Going to have to give up that full SN if you expect much help.
Syncrowave 180 SD
*HF-251D-1
*WC-1S & Spoolmatic 1
PakMaster 100XL
Marquette "Star Jet" 21-110
10-05-2012, 11:35 PM #9
- Oct 2012
- 17
10-06-2012, 01:43 PM #10
Yep, follow the disassembly instructions for that machine, you'll have to remove the generator and engine together. doesn't look terribly hard though.
