Results 1 to 5 of 5
    Oct 2012
    2
    Default Replacement Engine
    Is there a replacement for Onan P220G? That will bolt up to my machine?
    Aug 2008
    Orange, TX
    1,223
    Another Onan P220G?
    What machine and what's wrong with the current P220G?
    http://onanparts.com/
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    Oct 2012
    2
    Quote Originally Posted by lewisc View Post
    The machine is a Trailblazer 251 , A con rod came apart and did a lot of internal damage.Also magnet's are coming loose in flywheel.Would like to find a new engine for this machine.
    Aug 2008
    Orange, TX
    1,223
    Later Trailblazers were available with both the P220 Onan and Kohler CH-20 but what I can't tell you is if the later Kohler engine-to-stator adapter will fit your earlier 251.
    Syncrowave 180 SD
    *HF-251D-1
    PakMaster 100XL
    Oct 2007
    Cave Creek Az
    1,081
    Short answer, no. It is cheaper to buy another used TB.
