Results 11 to 14 of 14
    Oct 2012
    Default need advice on welding a cast iorn stove leg
    I have had good success with cast iron repairs using TIG with silicon bronze. It doesn't give you a good color match but welds very easily.
    Fallbrook CA
    20
    [ATTACH=CONFIG]each[/ATTACH][ATTACH=CONFIG]eachSlice[/ATTACH][ATTACH=CONFIG]all[/ATTACH][ATTACH=CONFIG]any[/ATTACH][ATTACH=CONFIG]collect[/ATTACH][ATTACH=CONFIG]detect[/ATTACH][ATTACH=CONFIG]findAll[/ATTACH][ATTACH=CONFIG]select[/ATTACH][ATTACH=CONFIG]grep[/ATTACH][ATTACH=CONFIG]include[/ATTACH][ATTACH=CONFIG]member[/ATTACH][ATTACH=CONFIG]inGroupsOf[/ATTACH][ATTACH=CONFIG]inject[/ATTACH][ATTACH=CONFIG]invoke[/ATTACH][ATTACH=CONFIG]max[/ATTACH][ATTACH=CONFIG]min[/ATTACH][ATTACH=CONFIG]partition[/ATTACH][ATTACH=CONFIG]pluck[/ATTACH][ATTACH=CONFIG]reject[/ATTACH][ATTACH=CONFIG]sortBy[/ATTACH][ATTACH=CONFIG]toArray[/ATTACH][ATTACH=CONFIG]entries[/ATTACH][ATTACH=CONFIG]zip[/ATTACH][ATTACH=CONFIG]size[/ATTACH][ATTACH=CONFIG]inspect[/ATTACH][ATTACH=CONFIG]find[/ATTACH][ATTACH=CONFIG]_reverse[/ATTACH][ATTACH=CONFIG]_each[/ATTACH][ATTACH=CONFIG]clear[/ATTACH][ATTACH=CONFIG]first[/ATTACH][ATTACH=CONFIG]last[/ATTACH][ATTACH=CONFIG]compact[/ATTACH][ATTACH=CONFIG]flatten[/ATTACH][ATTACH=CONFIG]without[/ATTACH][ATTACH=CONFIG]uniq[/ATTACH][ATTACH=CONFIG]intersect[/ATTACH][ATTACH=CONFIG]clone[/ATTACH]
    Get some Crown Alloys 44-30 .035 mig wire for cast iron and use your MM210. Any gas CO2, 75/25 or Argon will work well with it. Then you will have some wire left for the next job ...Bob
    Final recieved the crown royal 44-30 pricey but worth it, next question; can this be used to weld cast iron to wrought iron or do i need to cut up a old cast iron frying pan
    Harold PS hopefully I posted a few pictures
    Harold
    Craftsman Colormatic AC
    Victor Journyman Setup
    Syncrowave 180 SD
    MM210 With Spoolgun
    Dynasty 200 DX
    Spectrum 625 Plasma Cutter
    Miller HD Tape Measure
    Jul 2010
    335
    Wow, you're still dikking with this a month later? It's a 5 minute job with some SiB and a torch.
    asheville n.c.
    595
    Ac 7018 straight polarity
