Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
    Oct 2012
    1
    Default need advice on welding a cast iorn stove leg
    I have had good success with cast iron repairs using TIG with silicon bronze. It doesn't give you a good color match but welds very easily.
    Fallbrook CA
    20
    [ATTACH=CONFIG]each[/ATTACH][ATTACH=CONFIG]eachSlice[/ATTACH][ATTACH=CONFIG]all[/ATTACH][ATTACH=CONFIG]any[/ATTACH][ATTACH=CONFIG]collect[/ATTACH][ATTACH=CONFIG]detect[/ATTACH][ATTACH=CONFIG]findAll[/ATTACH][ATTACH=CONFIG]select[/ATTACH][ATTACH=CONFIG]grep[/ATTACH][ATTACH=CONFIG]include[/ATTACH][ATTACH=CONFIG]member[/ATTACH][ATTACH=CONFIG]inGroupsOf[/ATTACH][ATTACH=CONFIG]inject[/ATTACH][ATTACH=CONFIG]invoke[/ATTACH][ATTACH=CONFIG]max[/ATTACH][ATTACH=CONFIG]min[/ATTACH][ATTACH=CONFIG]partition[/ATTACH][ATTACH=CONFIG]pluck[/ATTACH][ATTACH=CONFIG]reject[/ATTACH][ATTACH=CONFIG]sortBy[/ATTACH][ATTACH=CONFIG]toArray[/ATTACH][ATTACH=CONFIG]entries[/ATTACH][ATTACH=CONFIG]zip[/ATTACH][ATTACH=CONFIG]size[/ATTACH][ATTACH=CONFIG]inspect[/ATTACH][ATTACH=CONFIG]find[/ATTACH][ATTACH=CONFIG]_reverse[/ATTACH][ATTACH=CONFIG]_each[/ATTACH][ATTACH=CONFIG]clear[/ATTACH][ATTACH=CONFIG]first[/ATTACH][ATTACH=CONFIG]last[/ATTACH][ATTACH=CONFIG]compact[/ATTACH][ATTACH=CONFIG]flatten[/ATTACH][ATTACH=CONFIG]without[/ATTACH][ATTACH=CONFIG]uniq[/ATTACH][ATTACH=CONFIG]intersect[/ATTACH][ATTACH=CONFIG]clone[/ATTACH]
    Quote Originally Posted by aametalmaster View Post
    Get some Crown Alloys 44-30 .035 mig wire for cast iron and use your MM210. Any gas CO2, 75/25 or Argon will work well with it. Then you will have some wire left for the next job ...Bob
    Final recieved the crown royal 44-30 pricey but worth it, next question; can this be used to weld cast iron to wrought iron or do i need to cut up a old cast iron frying pan
    Harold PS hopefully I posted a few pictures
    Harold
    Craftsman Colormatic AC
    Victor Journyman Setup
    Syncrowave 180 SD
    MM210 With Spoolgun
    Dynasty 200 DX
    Spectrum 625 Plasma Cutter
    Miller HD Tape Measure
    Jul 2010
    382
    Wow, you're still dikking with this a month later? It's a 5 minute job with some SiB and a torch.
  4. #14
    Feb 2007
    asheville n.c.
    618
    Ac 7018 straight polarity
