I have had good success with cast iron repairs using TIG with silicon bronze. It doesn't give you a good color match but welds very easily.
Results 11 to 14 of 14
10-03-2012, 10:38 PM #11
- Oct 2012
- 1
need advice on welding a cast iorn stove leg
11-06-2012, 08:01 PM #12
- Sep 2005
- Fallbrook CA
- 20
[ATTACH=CONFIG]each[/ATTACH][ATTACH=CONFIG]eachSlice[/ATTACH][ATTACH=CONFIG]all[/ATTACH][ATTACH=CONFIG]any[/ATTACH][ATTACH=CONFIG]collect[/ATTACH][ATTACH=CONFIG]detect[/ATTACH][ATTACH=CONFIG]findAll[/ATTACH][ATTACH=CONFIG]select[/ATTACH][ATTACH=CONFIG]grep[/ATTACH][ATTACH=CONFIG]include[/ATTACH][ATTACH=CONFIG]member[/ATTACH][ATTACH=CONFIG]inGroupsOf[/ATTACH][ATTACH=CONFIG]inject[/ATTACH][ATTACH=CONFIG]invoke[/ATTACH][ATTACH=CONFIG]max[/ATTACH][ATTACH=CONFIG]min[/ATTACH][ATTACH=CONFIG]partition[/ATTACH][ATTACH=CONFIG]pluck[/ATTACH][ATTACH=CONFIG]reject[/ATTACH][ATTACH=CONFIG]sortBy[/ATTACH][ATTACH=CONFIG]toArray[/ATTACH][ATTACH=CONFIG]entries[/ATTACH][ATTACH=CONFIG]zip[/ATTACH][ATTACH=CONFIG]size[/ATTACH][ATTACH=CONFIG]inspect[/ATTACH][ATTACH=CONFIG]find[/ATTACH][ATTACH=CONFIG]_reverse[/ATTACH][ATTACH=CONFIG]_each[/ATTACH][ATTACH=CONFIG]clear[/ATTACH][ATTACH=CONFIG]first[/ATTACH][ATTACH=CONFIG]last[/ATTACH][ATTACH=CONFIG]compact[/ATTACH][ATTACH=CONFIG]flatten[/ATTACH][ATTACH=CONFIG]without[/ATTACH][ATTACH=CONFIG]uniq[/ATTACH][ATTACH=CONFIG]intersect[/ATTACH][ATTACH=CONFIG]clone[/ATTACH]Final recieved the crown royal 44-30 pricey but worth it, next question; can this be used to weld cast iron to wrought iron or do i need to cut up a old cast iron frying pan
Harold PS hopefully I posted a few picturesHarold
Craftsman Colormatic AC
Victor Journyman Setup
Syncrowave 180 SD
MM210 With Spoolgun
Dynasty 200 DX
Spectrum 625 Plasma Cutter
Miller HD Tape Measure
11-06-2012, 08:25 PM #13
- Jul 2010
- 333
Wow, you're still dikking with this a month later? It's a 5 minute job with some SiB and a torch.
11-09-2012, 05:16 AM #14
- Feb 2007
- asheville n.c.
- 595
Ac 7018 straight polarity
...Bob
