Results 1 to 10 of 14
    Fallbrook CA
    20
    Default need advice on welding a cast iorn stove leg
    Have a cast iorn stove leg that has a chunk broken out. Any recomendations? Have a Millermatic 210, a Syncrowave 180 and a dynastey 200 DX. Can post some pictures tommorrow if it will help.
    Harold
    Harold
    Craftsman Colormatic AC
    Victor Journyman Setup
    Syncrowave 180 SD
    MM210 With Spoolgun
    Dynasty 200 DX
    Spectrum 625 Plasma Cutter
    Miller HD Tape Measure
    I don't know if you can still get it but there used to be a such thing as a nickle SMAW electrode for welding black cast iron. Seems to me I used to hear that it had hit-or-miss results usually due to cracking. Preheat is critical. Haven't heard anybody mention it in years. Most people braze cast iron with brass. There are youtube vids out there showing how it's done. You can also fusion weld cast iron with a gas torch and that's pretty much the best method but it's also the slowest as you have to weld it like a conventional weld with bevel prep and a lot of material deposit and a lot of powdered flux you dip the iron filler rod into periodically. It's hot, hot, hot and slooooooow.
    Jul 2010
    333
    I'd just braze it with a O/A torch and then paint it to cover the repair.
    Aug 2004
    Milan Michigan
    1,418
    I agree, Braze it.
    Salem ,Ohio
    3,653
    Cool
    Get some Crown Alloys 44-30 .035 mig wire for cast iron and use your MM210. Any gas CO2, 75/25 or Argon will work well with it. Then you will have some wire left for the next job ...Bob
    Mar 2006
    northwest Pa
    76
    I would preheat, use a nickle rod then cool slowly- like wrap with insulation.
    Good nickel welding rod is not available anymore. Brazing with brass will work, but brazing with bronze on cast-iron is the best. I use a nickel bronze rod made by Harris. We also use bronze to buildup the drive gears on Steam Tractors, and have never had a problem with a failure, unlike when others use an arc welder.
    Jeff Lund
    Lund Machine Works
    www.lundmachine.com
    Aug 2012
    Hermiston Oregon
    122
    This ones easy braze it. Pre-heat around 200°f. Wells with a nickle rod 55. Wrap with insulation tightly and let it cool over night. Don't peek. If you hear it crack start over. Really simple just time consuming. Good luck. ARE YOU SURE ITS CAST IRON ANS NOT CAST STEEL. THERES A BIG DIFFERENCE WHEN WELDING. CAST STEEL BEING MUCH EASIER.
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
    Aug 2007
    673
    Quote Originally Posted by aametalmaster View Post
    I would have to agree with Bob. Since you have a MM210 the easiest fix would be to mig it with Crown Alloys 44-33. Bob has had good success with this process in the past. Post some pictures before and after.
    Good luck,
    Nick
    Feb 2010
    YOUNGSTOWN, OHIO
    127
    Nickel welding rod is readily available. Use a 99 nickel rod. If it is made of grey iron, you're chances of success are good if you follow a couple basic rules. Number 1 is: if you do not have to restrain the weldment during welding, Don't, you will be better off. The primary reason for cracking is weld shrinkage. V-groove one side of the joint at least 75% and only weld one side. Position the broken piece so that as you are welding it, the weld shrinkage will pull it into the correct position. Preheat to at least 600 deg. weld an inch at a time and keep interpass temp at 600deg. Then cool very slowly. Post some pics.
    JIM
    Millermatic 350P Aluma Pro
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    Hypertherm Powermax 45 and 85
    Dake 75 ton H-Frame Press
    JD Squared Model 32 Bender
    Miller Digital Elite
