Have a cast iorn stove leg that has a chunk broken out. Any recomendations? Have a Millermatic 210, a Syncrowave 180 and a dynastey 200 DX. Can post some pictures tommorrow if it will help.
Harold
Results 1 to 10 of 14
10-02-2012, 09:01 PM #1
- Sep 2005
- Fallbrook CA
- 20
need advice on welding a cast iorn stove leg
Harold
Craftsman Colormatic AC
Victor Journyman Setup
Syncrowave 180 SD
MM210 With Spoolgun
Dynasty 200 DX
Spectrum 625 Plasma Cutter
Miller HD Tape Measure
10-02-2012, 09:16 PM #2
- Sep 2012
- 91
I don't know if you can still get it but there used to be a such thing as a nickle SMAW electrode for welding black cast iron. Seems to me I used to hear that it had hit-or-miss results usually due to cracking. Preheat is critical. Haven't heard anybody mention it in years. Most people braze cast iron with brass. There are youtube vids out there showing how it's done. You can also fusion weld cast iron with a gas torch and that's pretty much the best method but it's also the slowest as you have to weld it like a conventional weld with bevel prep and a lot of material deposit and a lot of powdered flux you dip the iron filler rod into periodically. It's hot, hot, hot and slooooooow.
10-03-2012, 02:23 AM #3
- Jul 2010
- 334
I'd just braze it with a O/A torch and then paint it to cover the repair.
10-03-2012, 12:48 PM #4
I agree, Braze it.
10-03-2012, 06:45 PM #5
Get some Crown Alloys 44-30 .035 mig wire for cast iron and use your MM210. Any gas CO2, 75/25 or Argon will work well with it. Then you will have some wire left for the next job
...Bob
10-03-2012, 06:58 PM #6
- Mar 2006
- northwest Pa
- 76
I would preheat, use a nickle rod then cool slowly- like wrap with insulation.
10-03-2012, 06:59 PM #7
- Feb 2010
- 10
Good nickel welding rod is not available anymore. Brazing with brass will work, but brazing with bronze on cast-iron is the best. I use a nickel bronze rod made by Harris. We also use bronze to buildup the drive gears on Steam Tractors, and have never had a problem with a failure, unlike when others use an arc welder.
10-03-2012, 07:17 PM #8
This ones easy braze it. Pre-heat around 200°f. Wells with a nickle rod 55. Wrap with insulation tightly and let it cool over night. Don't peek. If you hear it crack start over. Really simple just time consuming. Good luck. ARE YOU SURE ITS CAST IRON ANS NOT CAST STEEL. THERES A BIG DIFFERENCE WHEN WELDING. CAST STEEL BEING MUCH EASIER.
Miller Bobcat 225NT onan
Millermatic 211
Spoolmate 100
Miller 130xp
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
1/2" Aircat impact gun 900#
10-03-2012, 07:20 PM #9
10-03-2012, 08:01 PM #10
Nickel welding rod is readily available. Use a 99 nickel rod. If it is made of grey iron, you're chances of success are good if you follow a couple basic rules. Number 1 is: if you do not have to restrain the weldment during welding, Don't, you will be better off. The primary reason for cracking is weld shrinkage. V-groove one side of the joint at least 75% and only weld one side. Position the broken piece so that as you are welding it, the weld shrinkage will pull it into the correct position. Preheat to at least 600 deg. weld an inch at a time and keep interpass temp at 600deg. Then cool very slowly. Post some pics.
JIM
Millermatic 350P Aluma Pro
Maxstar 150 STL
Trailblazer 302
Suitecase 12RC
Extreme 12VS
Extreme 8VS
Spoolmatic 30A
Miller HF251D-1
Passport Plus
Spoolmate 100
Hypertherm Powermax 45 and 85
Dake 75 ton H-Frame Press
JD Squared Model 32 Bender
Miller Digital Elite
