Page 1 of 3 123 LastLast
Results 1 to 10 of 24
    Oct 2012
    Default question for an at home welder
    I don't have a 220amp plug so is there a good machine that I can get to do some basic welding? Mild steel nothing thicker than 1/4". I'm looking to keep costs down, any ideas?
    Mar 2011
    La
    174
    What type of welding are you thinking about doing: mig, tig, or stick? Thats going to make a difference in the responces you get.
    Diversion 180
    Millermatic 350P, XR-Aluma-Pro
    30A Spoolgun
    Lincoln Power Mig 180
    Lincoln Pro Mig 140
    Hypertherm Powermax 30
    14" Rage Evolution 360
    40 ton press brake
    Shop full of tools
    WY...armpit of U.S.A.
    640
    Besides knowing just what sort of welding process you are looking to get into, it would help to know if it were at all possible to run in a new circuit to have 220v power made available. It is a simple enough process to run a new circuit if the power service panel (breaker panel) is within easy reach of your shop/garage and almost as simple to run an extension cord from a nearby electric washer/dryer or stove outlet. Renting may make this option unattractive. If you decide you can have a 220 circuit installed, come back for further advice, as I mentioned before it is a quite simple installation.
    As far as non-240v powered welders go you'll see far less useful output from them. There are a number of MIG and multi-process machines offered nowadays that utilize 120-240v power plugs. Still, if it were me, I'd be looking for a unit that ran exclusively off 240v power.
    Cheapest process for your needs would be a stick welder. Limited somewhat in the available rod selection because of use of AC current and minimal current available in 120v operation.
    BTW, Miller has many articles available on-line on this subject, as well as the information available here on the forums from members. Either select from the drop down "Resource" menu for Miller factory information on the subject or do a search in the archives of the various forums by using the search feature and typing in the relevent search.
    Best of luck to you.
    Miller DialArc 250
    Lincoln PrecisionTig 275
    Hypertherm 900 plasma cutter
    Jet 14 X 40 lathe...ditto
    Logan 7" shaper
    Ellis 3000 band saw
    Lots of dust bunnies
    I knew a guy who built his own extension cord apparatus to run a 220v welder without changing any wiring in his house. He used a male plug and short cable that would normally be used for a stove, which you can find at any hardware store. He looked at the writing on the cable casing and bought some more of the same kind of cable. He wired the male stove plug into a small box which housed a single breaker and then ran the other cable to a female plug that his welder could plug into. The fuse was used only as a safeguard because the welder required less current draw then the stove circuit breaker was made to safely deliver. That means if there was a problem with the welder the stove breaker would not trip and a fire could possibly start. So he inserted the right size breaker for the welder into the middle of his cord. Then he just unplugged his stove and ran the cord out to his garage whenever he needed to weld something. It certainly didn't look pretty and it was a little inconvenient but it worked and he didn't have to spend a ton of money to build it. I think he said he did the whole thing for about a hundred bucks. Compare that to renovating the electrical system in your house to run a 220V plug out to your garage and it's cheap.
    You could also do the same thing with a clothes dryer circuit if that was closer.
    The guy used one of those plastic all weather boxes and I thought that was a smart idea.
    640
    The advice above about using an in-line circuit/fuse may not be to code even for a permanent installation (depending upon how the ground to the main panel had been run). Still, probably wouldn't be a deal breaker for me either...guy will do almost anything to get a welder up and running.
    Miller DialArc 250
    Logan 7" shaper
    Ellis 3000 band saw
    Actually I looked it up. There are no rules against using an extension cord to power a welding machine. Not around here anyway. The cord has to have wire heavy enough to be rated for the current draw. The circuit has to be fused to match the input draw of the machine and other than standard safety items like not laying cable in water and stuff like that there's not much else to comply with. I have worked for several fabricators who use extension cords to power their equipment and lots of them are the monster 600V 100A 3-phase kind.
    640
    Quote Originally Posted by Matrix View Post
    As I said before...don't sweat the details when a tool is down. As far as there not being "much else to comply with" is where I would take exception to what you recommended. When it comes to NEC compliance everything is under the gun, so to speak. In this case it would definately be the provision of adding an in-line breaker/fuse box in the extension cord. I believe that would definately be non-code for extension cords, but if permanently wired correctly back to the main service panel it would be okay. Without proper documentation/inspection of the previous wiring back to the panel, even on a permanent installation, I would be leery about offering the advice of just going with a cord from a dryer/stove outlet with a breaker/fuse installed in-line. Now as far as what your fabricators do/permit goes, they'll do anything within reason to get a job done. Matter of fact, I'd probably do the same.
    Miller DialArc 250
    Logan 7" shaper
    Ellis 3000 band saw
    Quote Originally Posted by WyoRoy View Post
    ... In this case it would definately be the provision of adding an in-line breaker/fuse box in the extension cord. I believe that would definately be non-code for extension cords, ...
    OK, now I get you. It's the "inline" fuse you think might be illegal, not the cord itself. I confess I don't think I looked up that aspect of it. I'm in Canada so we don't have NEC but I'm sure we must have something similar. I"ll look into it. That kind of info would be useful for me personally as well. Thanks for the heads up.
    Apr 2010
    150
    Power strips and extension cords with breakers aren't that uncommon.
    4,248
    Why would anyone put a breaker in a cord? Especially in residential and for a welding machine?
    As for the OP, you want to weld arounf the house from 120, Maxstar or similar machine, or a Hobart ez
