    Oct 2012
    Default DC Arc Welding, where to start...
    Hi, I purchased a Hobart 235/160 AC/DC welder (made by Miller I believe). I have been doing some AC welding but want to try DC. Is the Amperage Range listed on the Electrode chart for AC and DC or just AC?
    Using AC I'm currenlty using a 7014 3/32" rod at about 100 Amps and a 7014 1/8" rod at about 130 Amps. If you can provide some advice at what Amps I should be at using DC for these same rods I would appreciate it.
    Any suggestions would be greatly appreciated.
    Thanks,
    Steve
    Just play around with it. If your gettin undercut turn it down a bit if your rod is stickin turn it up a bit... Welds so much nicer on dc.... Good luck
    WY...armpit of U.S.A.
    659
    Fill in the blanks and you should get fairly close.
    http://www.millerwelds.com/resources...calculator.php
    Miller DialArc 250
    Lincoln PrecisionTig 275
    Hypertherm 900 plasma cutter
    Jet 14 X 40 lathe...ditto
    Logan 7" shaper
    Ellis 3000 band saw
    Lots of dust bunnies
    Jun 2009
    greenfield new hampshire
    889
    convert rod size to decimal, thats your starting point, for example, 1/8" rod is .125, 125 is your starting point
    now in Orlando!!!!
    559
    Thumbs up
    Quote Originally Posted by kevin View Post
    sounds like a great formula.........
    More Spark Today Please
    Default welding fencing
    Hi,
    I suggest you to concern to expert while working of this project, You may require lot to know more about Hobart 35/160 AC/DC welding. In some scenario it might be danger if you are proficient.
    Many Thanks.
    http://www.vhfencingwelding.com/
Tags for this Thread
