Results 1 to 6 of 6
    Default aluminum spool gun and bobcat 250EFI?
    have a 2012 bobcat 250 EFI and need to put a MIG aluminum spool gun into the equation for a project upcoming in the field. What do I need to make this setup work? I was told I needed to get a new Trailblazer instead from my local welding shop. Any way I can use an adapter to make work? Thanks!
    Oct 2004
    Edmonton, Alberta
    6,763
    Sure you need a WC-115 (with contactor) and a spoolmatic 30A
    can someone please confirm that I would need the following items then?
    quantity 1. WC-115A with contactor (part #137-546-01-1)
    quantity 1. Spoolmatic 30A (part #130831)
    anything else?
    Thanks!
    Appleton, WI
    371
    Those would be the correct items. You will need a chunk of weld cable to go from the Bobcat to the WC-115, for a work cable you can use your work cable that goes with your stick cables and of course you will need argon gas, aluminum welding wire and I would suggest some extra contact tips as well.
    Kevin Schuh
    Service Technician
    Miller Electric Mfg. Co.
    Kevin -- thank you.
    Feb 2007
    now in Orlando!!!!
    557
    Quote Originally Posted by Miller Kevin View Post
    Miller Kevin, is there any difference in the preformance of
    the two machines Bobcat vs Trailblazer, I have welded
    extensively with the Trailblazer and a 30A spoolgun, but not with
    the Bobcat..Trailblzer runs great even with a Promax gun....just wondering....Paul
    More Spark Today Please
