Page 1 of 3 123 LastLast
Results 1 to 10 of 26
    Default Cruizer, a question on a generator
    Cruizer, my welders are running fine,but I have a question on a portable generator which no one at this point has been able to solve. Just wondering if you can help. I bought it reconditioned a few years ago and never really checked the generator portion when I bought it.I checked out and started the motor,which was fine. It produces 110 volts at each respective 110 volt receptacle fine,but when I check for220 volts at its receptacle,there is 0 volts. On this very receptacle when I check across each hot lug independently I get 110 volts as I should,but when I check for the combined total at both hot lugs I get zero. I am confused on this one. I know this section is for welding questions,but so far have been unable to get an answer that may help reslove the problem. Then to,I don't know if it is even worth fixing given the potential cost. I bougt it from Home Depot and failed to check the generator portion when I purchased it.I guess I thought it would work properly being just reconditioned. Thanks for any input.
    Feb 2005
    N.E. SD
    1,381
    Obviously I'm not Cruiser, but my guess would be that the recepical isn't wired correctly. both hots are wired to the same leg of the generator.
    Jeff
    Aug 2004
    Milan Michigan
    1,896
    J Hall, That would also be my guess, If you go from hot to neutral and get 115 on each leg it should mean they are both tied to the same 115V leg.
    Aug 2008
    Orange, TX
    1,228
    What they said. ^^
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    Jun 2012
    Tracy, CA
    221
    I bought a generator from Costco and had to return it 29 days later when fuel started dumping out the bowl. A week after I returned it I received a recall in the mail.
    Lincoln Vantage 400
    Trailblazer® 302 Air Pak™
    Miller Dynasty® 350
    Millermatic 350P Aluminum
    Millermatic® 252
    Syncrowave 351
    Lincoln LN-25 Pro
    Multimatic™ 200
    XR-Aluma Pro Gun
    Diversion™ 180
    Spectrum® 625 X-TREME™
    Victor Oxy/Acetylene Set
    8,351
    Quote Originally Posted by J hall View Post
    And Ditto to the other guys.
    2,971
    Which model is it?
    By chance it doesn't have a 120v/240 toggle switch on it?
    No toggle switch,and thanks everyone.
    2,971
    Quote Originally Posted by NMWelding View Post
    Can you post up the Model #, just curious.
    The generator is a Homelite model HG6000.
