Guys, looking for some advice.
I have the need for attaching 3/16" and 1/4" diameter sst rod in a grid pattern. Looking for a fast and reliable means to do this. With my limited knowledge of welding, it seems like if I could rig up the tips of a spot welder to have good contact on these rounds, and I could get good force to these tips, I could spot weld these joints.
Any thoughts or am I way off base with this idea?
Results 1 to 7 of 7
Thread: Woodworker needs some help
09-28-2012, 06:16 PM #1
- Sep 2012
- 2
09-28-2012, 07:54 PM #2
Don't know what size spot welder you have but you may be under powered....Bob
09-29-2012, 12:51 PM #3
- Sep 2012
- 2
Thanks Bob for the reply, but I don't have a spot welder yet. I'm just trying to get input on if a spot welder could do the job, what size I need and if two steel rods at 90 degrees have enough contact area for a spot welder to work....?
09-29-2012, 01:03 PM #4
- Sep 2005
- WY...armpit of U.S.A.
- 640
Your typical spot welder, even the 220v variety, isn't going to give you the penetration necessary for your job. About the best you could hope for would be a bond similar to that a tube of JB Weld.
I believe that if you click on the link below you'll see that the maximum capacity of a Miller 220v spot welder is 3/16". That is 3/16" TOTAL thickness for both parts added together.
If you wish to go cheap...stick welder, easy...MIG welder and precision (but far from inexpensive)...TIG welder.
http://www.millerwelds.com/products/spotwelders/Miller 251...sold the spoolgun to DiverBill.
Miller DialArc 250
Lincoln PrecisionTig 275
Hypertherm 900 plasma cutter
Jet 14 X 40 lathe...ditto
Logan 7" shaper
Ellis 3000 band saw
Lots of dust bunnies
10-09-2012, 03:35 PM #5
- Dec 2007
- PA
- 288
whillyjo,
Did a real quick and dirty test with my Miller LMSW-52 on 1/4" diam stainless rod.
Pieces are about 3" long.
Tried to get good close up photos but the depth of field suffers the closer I got.
Anyway, one spot weld like this is easy. Took about 1 second.
Drawback is that you get burn marks on the outside surfaces.
I was sloppy so it may be better with practice.
Trade-off is that a cleaner looking short dwell time spot weld may not be as strong as a longer one.
My LMSW-52 has 12" tongs which reduces the amperage at the tips but I had more than enough power.
If I had held the switch down longer, I would have melted both rods.
Stainless has higher electrical resistance than carbon steel so this may make a slight difference.
I think the hardest part may to align your pieces and to hold them securely between the spot welder tips.
May require machining a special set so they won't slip.
Anyway, hope this helps.
http://www.millerwelds.com/products/...__air-cooled_/
Thermal Arc GTSW400, Airco Heliwelder II, Miller Dynasty 350, Hypertherm 1000, oxy-fuel setup, metal cutting bandsaw, air compressor, drill press, etc.
10-09-2012, 05:46 PM #6
maybe you can find something that will work for you
http://www.twpinc.com/wire-mesh/TWPCAT_5Ed Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
10-09-2012, 08:43 PM #7
- Sep 2011
- 7
