Results 1 to 1 of 1
    Nov 2010
    Default My next project involves alot of sheet metal TIG welding - seeking advise
    Hello all,
    first poster here A few words on where I'm at. Over the years I have built up a halfway decent shop, I have a Bridgeport mill, a Colchester lathe and a Dynasty 200DX welder. I have done small projects involving these machines (well not the lathe as I just got that), but I'm still very much a noob. Next project up is a go kart for my kids. Kids are very young so I have plenty of time
    I am planning a 1:2 - 3:5 scale 1932 Ford roadster for the kart. Needless to say it will involve all machines and a steep learning curve.
    First up will be fabrication of frame rails. I have exact digital drawings of the deuce frame which can be printed full size at any scale for a template. I plan 1/16" or 3/32" mild steel sheet for the frame.
    I'll cut the profile of the frame from sheet and weld together 4 pieces for a box section with the correct shape. I'll also try to cut, bend and weld the outer side pieces to imitate the ***y reliefs on the 32 frame.
    The TIG calculator on this site calls for the following:
    1/16" sheet:
    1/16" tungsten (I have thoriated and ceriated)
    1/16" filler
    50-80 amps + 10% for mild steel
    11-20 gas
    1/4" - 3/8" cup
    3/32" sheet:
    same, except 80-110 amps + the 10%
    Onto the questions:
    - any input on the sheet metal thickness? Frame will be around 75" long.
    - would you reckon the parameters from the tig calc a good starting point?
    - someone told me I should go with a closed corner with some stick up even to eliminate the need for filler? Or just go with an open corner and add filler?
    - I believe no gap between the pieces is important ie very accurate cutting?
    - Do I need to use a heat sink ie copper plate on the back side?
    - Should I break out the hammer and dolly and work the weld every few inches?
    - How close would you space your tacks?
    - How long a bead would you lay before moving to another part of the construction and continue there?
    Looking forward to hearing what you think
    JT
