Results 1 to 5 of 5
Thread: cutting setup
    Sep 2012
    5
    Default cutting setup
    When setting up a new cutting outfit, is it adviseable to put teflon plumbing or gas tape on the brass threads to prevent leaks?
    Teflon tape won't hurt anything. Never use oil, paste, putty, anti-seize, etc...
    Sep 2012
    London
    21
    Thanks for the useful tip.
    Nov 2009
    western mass
    211
    Default why?
    what would you need tape on? every new torch set i got had flare fittings on the hoses, regulators, and torch. i never had to put together anything with pipe fittings, unless changing the fitting on the regulator. it amazes me when people put tape on flare fittings. the seal is on the flare not the threads.
    Jul 2010
    Four Flags city
    304
    Teflon tape would only be used on pipe thread,never on any CGA gas fittings.
    http://www.concoa.com/cgachart.html
