Page 1 of 3 123 LastLast
Results 1 to 10 of 28
    Default Death by oil drum.
    Well another one had died trying to cut up an oil drum.
    http://www.bbc.co.uk/news/uk-england...shire-19035426
    Feb 2007
    now in Orlando!!!!
    557
    Quote Originally Posted by jmpgino View Post
    a little dry ice would have prevented this......or good ole soap and water.....hopefully other readers will get something from this......Paul
    More Spark Today Please
    Salem ,Ohio
    3,655
    Cool
    Quote Originally Posted by paulrbrown View Post
    Or a meter to sniff out vapors. You must be 100% positive that it won't blow before you start any cutting or welding. If not 100% i won't touch it...Bob
    Jan 2012
    Metro Detroit, MI
    182
    Default Lifesaver
    I never really thought twice about cutting 55 gallon drums until coming to this forum. I knew the danger and took precautions but now I think twice and purge first. I have a fuel tank that seperated at the welds I need to repair.
    Never Satisfied
    Millermatic 211
    Maxstar 150STL
    Metabos
    Kennedy Maintenance Pro Full
    Makita Cordless 18v Li-Ion
    Stihl TS 420
    Timfrank88@live.com
    Nov 2003
    2,019
    Quote Originally Posted by Rezeppa View Post
    I have always preferred a thorough wash out with a steam jenny..to boil out the flammables followed by a few chunks of dry ice before and during welding to displace the oxygen and explosive gasses....
    that is of course under ideal conditions....
    The more you know, The better you know, How little you know............................. (Old Estonian Saying)
    Dec 2009
    718
    Some CO2 and problem solved, the guy should have read some post on this forum.
    R.I.P.
    Nov 2009
    western mass
    133
    people just dont think about things sometimes. most dont know but even people that do sometimes do things they think about later and say wow that was close. these thing remind us of things not to do
    4,247
    I almost did one a while back, finally remembered, crap, we had gas in that at one point.
    May 2012
    1
    Default dry ice
    Can you tell me in what way the dry ice would be used to prevent this. I've not heard of this before. Thanx
    Aug 2004
    Milan Michigan
    1,418
    I've welded on about 10 fuel tanks already this year, some diesel, some gas and some hydraulic oil.
    You need to treat them all the same because you never know when they did you a favor and clean them up with gas, break cleaner, starting fluid etc.
    Even when welding on a cracked aluminum oil pan that is still on the car or truck.
    You need to use an inert gas ( Helium, Argon, Co2, nitrogen )
    On a 55 gallon drum I have even filled to the top with water and started cutting right away as the water flows out.
    If your not 100% positive how to do it then dont.
