Results 1 to 10 of 12
    Default cutting expanded?
    What is the fastest and easiest way to cut expanded steel?Thanks.
    100
    The fastest and easiest is a shear.
    Since I don't own one, I use my plasma with a straight edge guide.
    Sep 2002
    Clark County, NV
    2,696
    Ditto. I'm so po', I didn't even think of the shear. I use plasma. This is where you need a GOOD, modern plasma, though, because the old-style and even the new cheap ones don't have the automatically relighting pilot arc.
    Jun 2006
    Ontario, Canada
    9
    And if you're even poorer you can use an angle grinder
    Sep 2002
    Clark County, NV
    2,696
    I've used a sawzall with decent results, too. You don't even need the straightedge because the expanded diamonds will recenter the blade for you for each little cut.
    Dec 2005
    Pennsylvania, USA
    20
    Circular saw with abrasive wheel has worked for me...
    Syncrowave 250DX
    Millermatic 250X
    Hypertherm PowerMax 1100
    Jun 2006
    18
    i just use a grinder on a straight line
    Eric
    "Why go around the mudhole when you can go through it"
    Miller Bobcat 250
    Miller Syncrowave 200
    Lincoln Pro-Core 100
    Feb 2006
    411
    I have even used a jigsaw with a metal blade for tight places and it worked good
    but always wear your safty goggles.......those metal bits get everywhere .
    Jan 2006
    Antigonish, Nova Scotia, Canada
    33
    What about just using your stick welder with a E6011 rod - quick and easy
    Hey richcharles what rod size should I use?I have some 60/11 they are 3/32 and 1/8.
    Stickwelds
    millermatic 251
    thunderbolt xl
    hypertherm powermax 380
    jet bandsaw
    delta chopsaw
