Hay Cruiser. going to depend on you to keep us updated on this thing. Just watched the videos and it looks to good to be true, but the low speed operation would be sweet.
I'll hang on to my 302 for a while till all the bugs are out of it.
Results 11 to 20 of 32
Thread: Trailblazer 325?????????????????
09-24-2012, 06:02 PM #11
- Jan 2007
- S.W. Missouri
- 143
Trailblazer 302
Lincoln SP-135-T
Hobart Stickmate AC/DC
Smith torch
Spoolmatic 30A
09-24-2012, 11:17 PM #12
Member
- Jun 2012
- Alberta
- 57
09-25-2012, 08:43 AM #13
Trailblazer® 302 Air Pak™
Miller Dynasty® 350
Millermatic® 252
Syncrowave 351
SuitCase® X-TREME™ 12VS
Millermatic® 211 Auto-Set™ w/MVP™
Spoolmate™ 100 Series
Diversion™ 180
Spectrum® 625 X-TREME™
09-25-2012, 04:24 PM #14
Basically using an ac - ac sinewave gererator to maintain 60HZ at low and high rpm. simple and interesting idea really
Engine rpm is adjusted with Kohlers electronic Governor
The weld output looks like the chopper on the Pipepro 350, and a red brand I know of.
There isn't a tech manual for it, so I can't say much else about it.
09-26-2012, 06:22 PM #15
We got it in yesterday and I welded with it all day today. Weld like a dream , smooth consistent arc! And it is super quiet! I welded with 6011 1/8 and 7018 3/32 and I was well pleased with this machine, ran it all day and didn't burn near as much gas as our old TB. Didn't run any power off of it though
09-26-2012, 08:20 PM #16
Member
- Jun 2012
- Alberta
- 57
so how did it compare to a 302 tb???
09-27-2012, 10:24 AM #17
I like the 325 alot better, all around, had one problem with it today. It ran all morning and we shut it off and when we came back and tried to crank it didnt want to run, like it wasn't getting no gas, fooled with it a few mins and it finally started running again, but still on one tank of gas
09-28-2012, 09:59 AM #18
Latest on new Trailblazer
Here's the landing page with several new videos (Bobcat and Trailblazer):
http://millerwelds.com/kickgas
EFI seems to make a big difference.
09-28-2012, 06:12 PM #19
Member
- Aug 2010
- Chesapeake, Va
- 96
I would just like to hear the noise of the machine instead of hearing the people talk that is my big selling point to buy one. I want to know how quiet it is in real site applications within different amps and power loads.
Miller pro 300 perkins diesel, 30 amp spool gun , Hobart 210 with spool gun, Thermal dynamic pak master 75 all mobile all ready to go.
10-01-2012, 04:46 PM #20
- Sep 2012
- 12
high revv
if they can do what they say with the 325 then they should improve all of the other machines, from high dollar to low. however ,they should not reduce the gas tank size. even though mig is not used much on welder/generators, they shoud all say that they can run mig without it revving up. if they did then the other processes would also benifit!
