Page 8 of 12 FirstFirst ... 3456789101112 LastLast
Results 71 to 80 of 117
  1. #71
    Lake of the Ozarks MO
    3,596
    I never said "Stupid", unsure where that came from.
    Now the cable doesn't come in one piece sooo...
    For a RCCS-14 you'll be needing the following:
    039273 - amp conector c/w pins
    151146 - 26.5' cable
    215030 - tubing
    209313 - 5 terminals required
    209314 - connector
    Sorry Cruizer,
    I wasn't meaning any one was calling anyone stupid
    I have simply grown to have enuff dislike for this cable and the lack of being able to buy it assembled, to begin to call "IT" (the cable) stupid.
    I was simply hoping you would just yank a rabbit out of your hat....in the form of a Miller cable for my controller. I have bought the repair kits and have had pretty poor service from them after that. I will check out some different cable. They do go thru a lot of abuse.
    Thanks, Garry
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
  2. #72
    May 2012
    Illinois--Land of Multi-Convicted governors :(
    3
    Question Break-in of new 275 TB
    Greetings Cruizer, thx for this thread and all your help to everybody on this website. Picking up a new 275 TB and wondering if you still recommend to burn a 50# box of rod to break-in the motor / welder? Any help is appreciated. Tricked Up
  3. #73
    8,351
    Quote Originally Posted by Tricked-Up-Welding View Post
    Gassers don't really need a breakin, so weld away....
  4. #74
    Oct 2012
    6
    Hello Cruizer- How bout this one-
    We have a 1991 Syncrowave 250 SN KB 0429xx that only works with the remote switch set to remote and using the foot pedal, not when set to panel position, trying to arc weld with it.
    Im going to order a new remote-panel switch S3 ( part # 052769 ) right ? and replace that and I wonder if there is also a relay that may be a cause that I should have on hand just in case while I have it opened up?
    Have fingers crossed that its not the PC board. Thanks, Dave
  5. #75
    8,351
    Well, if its just your amperage not working, then it's likely the switch itself, as the remote has to go through the exsisting local control potentiometer, so we know thats ok, and obiously the board is ok.
    That said, your NOT going to get HF in local control
  6. #76
    Oct 2012
    I have a Bobcat 225G. It will weld on AC buit not DC. What is the problem?
  7. #77
    Jun 2012
    Alberta
    57
    Hey Cruizer i bought a new TB302 and when i start it up and the first thing i do is use a grinder or drill with it there is no power till i put it on high idle and grind the first time is this normal?
  8. #78
    Corunna Ont, Canada
    458
    OK I have one. Not really something you couldn't figure out, but still a problem for me.
    I use the RCC-14 control on all my tigs. From time to time the cables go bad, right at the controller. I've bought the little repair kits and had mostly bad luck.
    Mainly because I ain't that good with that small of wire. Besides I need to be welding with my time.
    My Miller rep doesn't show just the cord available. I have a pile of this stuff laying around and it is bound to get bigger.
    I would love to find a place to just buy the control cable and not the entire assembly. Any ideas?
    Simple fix........ go wireless
    Railmen
    2007 Trailblazer 302G
    2004 Invision 354MP
    1999 60 series feeder
    2005 Maxstar 200DX
    2007 CST280
    1999 HF 251-1
    older Hobart hefty wire feeder
    Hyperthrem 600
    Maxstar 150S(such a cute welder)
    had and sold........
    2003 XMT 304CC/CV
    1947 Lincoln SA200G short hood
    1963 Lincoln SA200G
    1975 Lincoln SA200G(best machine ever had )
    1970's Lincoln SAE400G
    2 Maxstar's 200DX's
    1 Maxstar 200SD
    CST 280
    2 CST 250
    MM130
    Railmen
  9. #79
    8,351
    Quote Originally Posted by Lorin View Post
    Broken or burn't finger in the selector controller, or your not turning the selector fully into DC.
  10. #80
    8,351
    Quote Originally Posted by weld007 View Post
    Nope, not normal, for some reason its having a hard time building up voltage.
