Page 10 of 12 FirstFirst ... 56789101112 LastLast
Results 91 to 100 of 117
  1. #91
    Feb 2013
    5
    Got some issues with my TA186 with the arc on DC and sometimes not starting when hitting the pedal.
    Any thoughts or ideas?
    Here is my whole thread
    http://weldingweb.com/showthread.php?t=234901&page=4
    Hobart Handler 140 Mig
    HTP 221 tig
    Hypertherm Powermax 45
  2. #92
    Feb 2007
    asheville n.c.
    595
    Got a 301 tb that won't weld... Only 1900 hours on it. Been in shop two years now
  3. #93
    Dec 2011
    247
    Quote Originally Posted by beamwalker View Post
    Have you tried another shop? They may be a bit complicated but they're not 2 years complicated. By now I'd be just a little bit irritated.
    Meltedmetal
  4. #94
    Feb 2013
    8
    Thats easy! One of your output capacitor 20K ohm drain resistors is shot
    I use ohmite # L25J20KE. With a small pencil flame torch, remove the offending resistor, and with a soldering gun install the new resistor, you'll have to slightly cut the tabs on the new resistor to fit the slots though.
    OK, resistor R4 is bunk, this explains why C3 drains so slow. You can prolly guess how I figured out how slow it drained. The machine had been unplugged for 20 + mins and it still bit me. I Know, test the caps...
    Kelly
  5. #95
    Feb 2013
    8
    I ended up replacing both resistors. Works like a champ.
    Kelly
  6. #96
    Oct 2004
    Edmonton, Alberta
    6,763
    Change the freaking power board, and it'll be just fine... And yep might want to change your tech as well.
  7. #97
    Oct 2004
    Edmonton, Alberta
    6,763
    Quote Originally Posted by Gamble View Post
    Likely a preflow delay, accessed by a sub menu in the machine... I'll have a gander at the tech specs later...
  8. #98
    Jan 2013
    Norman,Ar
    6
    Default MM250X wire speed won't adjust.
    MM250X..KJ1976... serial # (99 model)
    No meters...
    No matter where you set the wire speed at, It will start out and run too fast..The control makes no difference on the speed..
    The control pots are new(both,wire speed and current).
    It was doing the same thing before change of controllers...
    It will weld, and the current will adjust properly...but the wire speed is way to fast..
    The Hot start has been disconnected...Diode D13 clipped ..Board # 188562.
    Any ideas besides replace the control board...Thanks for any ideas...
  9. #99
    Oct 2004
    Edmonton, Alberta
    6,763
    Always a control board issue, replacing the pots was completely useless
  10. #100
    Jan 2013
    Norman,Ar
    6
    Ok,,,I'll check to see where to acquire one...
    Thanks for the info...Trav..
