Page 7 of 12 FirstFirst ... 23456789101112 LastLast
Results 61 to 70 of 117
  1. #61
    Oct 2012
    Neosho Mo
    75
    Smile
    Hello by the way.
  2. #62
    Oct 2004
    Edmonton, Alberta
    8,020
    Innershield or dual shield, big difference, what kind of machine are you using?
  3. #63
    Oct 2012
    3
    Default ticking noise
    My dynasty 200dx making weird tick/click noise when I press the pedal. I remove the case to see its the arc jumping the points. The machine was fine the last time I used it.
  4. #64
    Oct 2012
    Neosho Mo
    75
    Default 12 vs trouble
    An airco wasp 180 near equivalent to a Miller roughneck
    I just got the 12vs I did my best to study up beforehand but guess not enough
  5. #65
    Oct 2004
    Edmonton, Alberta
    8,020
    Quote Originally Posted by MikeHunt View Post
    Quite normal as the machine is charging and discharging all the time, to either maintain the arc, or when not welding maintaining an internal charge, and of course the hf makes a noise, depending on the year.
  6. #66
    Oct 2012
    3
    I having erratic arcs and the display panel blinks when on the pedal. I know these dynasty have a humming/whine sound.
  7. #67
    Oct 2004
    Edmonton, Alberta
    8,020
    Open er up, and check the voltage pickups, just behind the output studs, likely the brass nuts that hold the pickup plate is loose. tighten them and red loctite the nuts in
  8. #68
    Oct 2012
    Neosho Mo
    75
    Default 12vs trouble
    Can you explain the difference between inter shield and dual shield and why it makes a difference
  9. #69
    Oct 2004
    Edmonton, Alberta
    8,020
    Innershield uses no gas, Dual shield uses gas (CO2)
    Innershield is (generally) straght polarity so pos is to the work clamp, and pickup off the VS feeder and neg to the feeder's lug
    Dual shield is reverse polarity, so pos to the lug and neg to the work clamp and pickup
  10. #70
    Oct 2012
    Neosho Mo
    75
    Thanks for your help cruzer
