Results 1 to 10 of 17
Hybrid View
    Sep 2012
    7
    Default Bobcat 225 NT died and will not do anything
    Yesterday I was using my Miller bobcat 225 NT as a generator, I had it hooked up to the meter loop of a shop I am building to check some electrical wiring I installed prior to getting electrical service. While actualy making sure some equipment worked in the shop, the Miller Bobcat died (no sputtering or hesitation it just died) while running at high idle, the machine would not do anything when I attempted to start.
    The battery is new, I have not checked because it was raining last night when this happened. The fuel tank is full and the oil level is good.
    Could this be a fuse, I read that the F-6 fuse when blown the welder would not start. Whould the blown fuse cause the machine to die and not even turnover?
    I need help?
    Oct 2004
    Edmonton, Alberta
    6,755
    Well, yep, cause ther would be no power going to the coil. nor to the starter.
    Why it happened though is a dilema. Did you hook your supply power to test your circuits correctly? ie, it more sounds like you grounded one of the live circuits back to the frame of the machine. That would be the only reason I could think of to take out that fuse.
    There just may be further damage besides the fuse, as the DC system doesn't particularly like AC being pumped into it.
    Aug 2008
    Orange, TX
    1,052
    If the starter solenoid doesn't even click, that's a pretty good sign fuse F6 is open. If it clicks but won't engage/turn over, check your battery as the charging regulator is probably bad.
    I doubt your testing hookup had anything to do with blowing F6 and I would check flashing diode D4 to see if it's shorted closed.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    Oct 2004
    Edmonton, Alberta
    6,755
    There would have to be a heavy draw on the 12 VDC systom to open F6, like a dead short. I just guessed since you were powering an auxillary circuit when this happened, that that system could be the culprit, or it was simply coincedence.
    Never the less report back what you discover. Oh a dead battery, non charging, or low oil would not take that fuse out.
    Aug 2008
    Orange, TX
    1,052
    I did consider the dumping of a heavy auxiliary power load while testing could result in a spike of exciter voltage which could take out (short) flashing diode D4 and backfeed the battery circuit thus blowing F6.
    But as you know, F1 should blow first if such were to happen so . . . ???
    I agree "a dead battery, non charging, or low oil would not take that fuse out" but a bad regluator could and I wouldn't rule out a battery/ignition circuit wire shorted to ground either.
    I too am curious as to what the OP finds.
    Syncrowave 180 SD
    *HF-251D-1
    PakMaster 100XL
    Oct 2004
    Edmonton, Alberta
    6,755
    Smile
    I have my doubts that he is going to report back, most never do.
