Results 1 to 10 of 11
Hybrid View
    Jul 2009
    Australia
    980
    Default Tube End Cap Clamping System
    Many times I have had to weld an end cap onto a round or square tube to finish a project.
    Not being much of a round tube welder I always hate this part of the fabrication and in fact I try to avoid it.
    A part from trying to do an ali bicycle frame weld (which I am not at that level) the other issue is clamping the end cap onto the tube. Sure if the tube is short no problems but what if you are working on a table leg or something even longer, then it gets harder. You have to hold the end cap in place while you get it centred and then tack weld it.
    Many times I have dipped my welding helmet to find a clamp has moved.
    Enough of that.
    Today I started fabricating a tube end cap clamp that fixes to the end of the tube right where it needs to be welded.
    Ji
    Grip it and Rip it
    Salem ,Ohio
    3,653
    Cool
    Nice work. I don't cap fancy parts like yours but i do cap steel tube at work....Bob
    Jul 2009
    Australia
    980
    Thank you for the kind words Bob.
    Ji
    Grip it and Rip it
    Jul 2009
    Australia
    980
    6mm Thick ali angle to 15mm thick ali flat bar.
    Tacking is really required or the flat bar will bend at the cut when the heat gets applied. Had to twitch the bar a little in my press to keep it dead straight.
    Welding over, now for some drilling and finishing.
    Ji
    Grip it and Rip it
    Jul 2009
    Australia
    980
    Finished !
    Works great and does not look to bad to boot.
    Can clamp round tube from 20mm to 75mm and similar for square tube.
    Time to start welding on some end caps on those projects.
    The difference this time is that I am looking forward to it.
    Ji
    Grip it and Rip it
    Mar 2006
    108
    JI,
    I agree, short pieces are easy enough to find a way to clamp the ends on. Several months ago I had some pieces that were about 5.5 feet long. To position the end caps I modified some magnets that stuck to the tube, and would also hold the cap in position. It works pretty good, and they do sell a magnet clamp that will do the same thing. It is basically 2 magnets held together by adjustable plates that can be placed and locked at various angles. I wish they would come out with an aluminum and stainless magnet.
