Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
    Sep 2012
    seaford de
    335
    Quote Originally Posted by admweld:293070
    How much gouging can you do with that many amps and that size compressor?
    I havnt done it my self but people are gouging with little inverters these days. They even make some with a gouge setting.
    Jun 2012
    Tracy, CA
    175
    I've been thinking of building a trailer too. I don't have much room to haul in my truck bed with a Trailblazer mounted in the middle.
    How long is your trailer? When you're carrying a 20' bar is there enough room between your trailer and truck?
    Trailblazer® 302 Air Pak™
    Miller Dynasty® 350
    Millermatic® 252
    Syncrowave 351
    SuitCase® X-TREME™ 12VS
    Millermatic® 211 Auto-Set™ w/MVP™
    Spoolmate™ 100 Series
    Diversion™ 180
    Spectrum® 625 X-TREME™
    Sep 2012
    seaford de
    335
    Quote Originally Posted by kvwall:293154
    The trailer is only 6' long but i extended the rack over the tongue a little ways.. it hangs off the back and the front so whenever i get something with it the material has to be sturdy.. if i get flimsy round rod i have to use flat bed or buy angle along with it. As far as it hitting the truck... nah. Its over the bed a little bit but its far enough up not to be a worry
  4. #14
    Sep 2012
    1
    Default Small Welding Rig
    That is one fine rig. I can see you having many uses for it. Thanks for sharing here
