Results 1 to 5 of 5
    Jan 2007
    Rosetown, SK.
    519
    Default Automotive oil cooler
    Wondering if anyone can tell me how to repair this oil cooler. Looks like a solder joint except it is an aluminum cooler.Would like to learn to repair these instead of sending to a rad shop. Any help appreciated.
    252 Miller Mig
    180 Synchrowave
    R - 45 Milling Machine
    Kingston 1100 Lathe
    Miller 2050 Plasma Cutter
    Oct 2004
    Edmonton, Alberta
    8,110
    Understandable, though it's much less hassle and somewhat cheaper to let someone who has done 1000 of these at a rad shop. And it's silver solder in case you were wondering. The cooler is hot dipped in an acid solution to remove all the contaminates - oils - . Don't know how you were planiing to do it....
    Jan 2007
    Rosetown, SK.
    519
    Is silver solder compatable with aluminum though?
    252 Miller Mig
    180 Synchrowave
    Kingston 1100 Lathe
    Oct 2004
    Edmonton, Alberta
    8,110
    Sorry, misthinking, I've been using a brazing rod AL-822, flows nice. Don't know why I had silver solder on my mind, probably as I use so much of it....
    Last edited by cruizer; 09-12-2012 at 08:01 PM. Reason: Can't type, can't think, yikes....
    Jan 2007
    Rosetown, SK.
    519
    Cruiser, Thanks and much appreciated,Wayne
    252 Miller Mig
    180 Synchrowave
    Kingston 1100 Lathe
