Results 1 to 7 of 7
    Jun 2012
    Tracy, CA
    221
    Default Stainless Flux for Keg
    Has anyone ever converted a SS keg into a brew kettle? I've seen a few YouTube videos but I want to get the viewpoint from experienced welders.
    I'll TIG weld the fitting in with Argon. What kind of flux should I use to keep the backside clean?
    Trailblazer® 302 Air Pak™
    Miller Dynasty® 350
    Millermatic 350P Aluminum
    Millermatic® 252
    Syncrowave 351
    Lincoln LN-25 Pro
    SuitCase® X-TREME™ 12VS
    Multimatic™ 200
    Millermatic® 211 Auto-Set™ w/MVP™ (Sold)
    XR-Aluma Pro Gun
    Diversion™ 180
    Spectrum® 625 X-TREME™
    Victor Oxy/Acetylene Set
    Sep 2012
    seaford de
    407
    Quote Originally Posted by kvwall View Post
    The only flux i know of for stainless tig is for pipe penetration. U can try closing it off and purging it with argon. If your getting a sugaring effet on the backside then you are welding too slow
    Jun 2012
    Tracy, CA
    221
    Thanks but purging is not an option. My LWS hooked me up with some Type B Solar Flux. I've been testing with it on some scrap but not too happy with the results yet.
    Miller Dynasty® 350
    Millermatic® 252
    Syncrowave 351
    Lincoln LN-25 Pro
    Multimatic™ 200
    XR-Aluma Pro Gun
    Diversion™ 180
    Sep 2012
    seaford de
    407
    What problems are you having?
    May 2012
    27
    I would tig with pulsing. Do you have pulse setting on you welder?. I weld stainless pipe for a food dist. Here in town and the only way I can get a clean weld inside is using my pulse settings. Good luck!
    Jun 2012
    Tracy, CA
    221
    Quote Originally Posted by weldonwelding View Post
    Porosity seems to be my biggest issue. It's definitely better than no flux but I like to do a better job.
    Miller Dynasty® 350
    Millermatic® 252
    Syncrowave 351
    Lincoln LN-25 Pro
    Multimatic™ 200
    XR-Aluma Pro Gun
    Diversion™ 180
    Jun 2012
    Tracy, CA
    221
    Quote Originally Posted by Gaby View Post
    I don't have pulse on the Diversion 180. The job is done now. I used the flux as directed then used a wire wheel to clean it up.
    Miller Dynasty® 350
    Millermatic® 252
    Syncrowave 351
    Lincoln LN-25 Pro
    Multimatic™ 200
    XR-Aluma Pro Gun
    Diversion™ 180
