Results 1 to 10 of 16
    Sep 2012
    seaford de
    407
    Default build heavy chain
    Start out with some 3/4 round rod cut about 3' pieces, then make a template from plate thats at least as thick as the rod. Tack the plate to work table. Tack one end of the rod to the template as shown. Heat and bend. Leave enough gap or bevel for 100% penetration. Weld with 7018 or mig
    Aug 2006
    Raymore Missouri
    1,920
    Why not make the link in one piece, then put the middle piece in.
    Nick
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Sep 2012
    seaford de
    407
    Default why not?
    Quote Originally Posted by monte55:292962
    Because you have to put it together.....
    Apr 2011
    367
    I am not a chain expert but I think you are missing the point of the middle piece, and monte55 is correct but you need to figure out how. Your chain is NOT safe like that and by no means "HEAVY" duty.
    Just For Home Projects.
    Sep 2012
    seaford de
    407
    No your right.... its just HEAVY! Im sure its not gona break jus hangin there. I tried a few different ways before i did it this way and found that this was the fastest and easiest. To make a whole link u gota leave one side open for the next link.. then it doesnt go back on the template so it doesnt stay uniformed.
    Aug 2010
    Chesapeake, Va
    108
    What is the chain for?
    Lincoln Vantage Kubota diesel 30 amp spool gun , Hobart 210 with spool gun, Thermal dynamic pak master 75, miller 304xmt all mobile all ready to go.
    Sep 2012
    seaford de
    407
    Its jus for decoration.
    Sep 2012
    seaford de
    407
    Default pic of what chain is used for
    I thought i added this photo in the beginning
    Salem ,Ohio
    3,953
    Cool
    Thats cool. If you had a Hossfeld bender you wouldn't need the heat...Bob
    Sep 2012
    seaford de
    407
    Yes they are very handy. One day i will invest in one... soon as my wallet recovers from paying for the ironworker i just got.
