Results 1 to 10 of 12
    Jul 2009
    Australia
    1,004
    Default Ali V Blocks For Holding Stock To Be Welded
    I am always TIG welding ali or Stainless Steel so using magnets to hold stuff together when tacking is not an option. My bench top is ali so I can not weld fences onto it to frame weldments.
    So I usually end up using 6 clamps to hold 2 sticks together while I tack. I can not say how many times I have put my gloves on, picked up my filler rod & flipped my helmet down just to have a clamp give.
    With that said I had some time today to make up some "V" blocks to help hold weldments together.
    6061 Ali sections.
    Ji
    Grip it and Rip it
    Jul 2009
    Australia
    1,004
    The "V" blocks hold just about every shape with just one clamp which I mounted to the "V" block.
    Ji
    Grip it and Rip it
    Jul 2009
    Australia
    1,004
    Today I started working on the support system.
    I have attached it to the members under my welding bench.
    Ji
    Grip it and Rip it
    Jul 2009
    Australia
    1,004
    Fix bracket.
    Ji
    Grip it and Rip it
    Jul 2009
    Australia
    1,004
    I needed to turn down this 25mm X 25mm square bar so it aligned with the main shaft.
    The problem is that I don't have a four jaw chuck for my lathe. I rang up my rep but he could not get an adapter plate for a week to fit a new four jaw chuck.
    I thought about the problem for a while and came up with a red neck way to get the job done.
    Snap On would not like this use for their sockets so I used a KC Pro.
    Not perfect but better than what I expected and the job was done today not in two weeks.
    Ji
    Grip it and Rip it
    Jul 2009
    Australia
    1,004
    Tig welded to main shaft.
    I have been using the Vee Blocks this whole build.
    Ji
    Grip it and Rip it
    Jul 2009
    Australia
    1,004
    Finished off the project today.
    Ji
    Grip it and Rip it
    Jul 2009
    Australia
    1,004
    With this new clamping system I should be able to hold just about any shape at any angle for welding.
    I will start thinking up more attachments to help.
    Ji
    Grip it and Rip it
    Mar 2011
    st-eustache qc.canada
    106
    Thumbs up The problem is that I don't have a four jaw chuck for my lathe.
    Thank-you for sharing this work , very nicely done.
    an old machinist showed me years ago how to stay away from 4 jaws chucks that are a pain to set up for repeatability. I use this method fro drilling and boring a hole in a cubic piece, acuracy is within 0.005 in. and better. And i really needed some practice on sketch-up (still need some more).
    We machine a larger and thick wall tube to the timension of the diagonal dimension of the square and leave a shoulder at the bottom, it can be put on the 3 jaws internally or externally. set screws can be added to hold the cube.
    Jul 2009
    Australia
    1,004
    Hi Snowbird.
    I think your cad skills are just fine.
    That would certainly work great.
    My problem is that I only lathe square once a year.
    Not much of a need for a 4 jaw chuck.
    The socket idea worked great but not to any real tolerance.
    Thanks for the kind words.
    Ji
    Grip it and Rip it
