Results 11 to 13 of 13
Thread: Tie Ins ???
    Dec 2008
    Arizona
    804
    If you're stick welding pipe, you will need to grind your start and stops on your root pass, but the remainder should be good to go unless you have a cold start. When you get back to it I sometimes have to grind a bit of the start of the bead to ensure good tie ins at the toes of the weld.
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
    May 2012
    208
    Default Tie Ins ???
    Just weld hot no welding imperfections live in high heat run as hot as you can .. Learn to move fast then you make flawless pretty welds and don't have to grind sh$ t
    Oct 2012
    4
    Actually if you weld too hot and fast undercut will take place
