Page 4 of 4 FirstFirst 1234
Results 31 to 35 of 35
  1. #31
    Raymore Missouri
    1,920
    Cool, that's where it belongs
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
  2. #32
    Dec 2012
    Sweetwater, TX
    201
    Quote Originally Posted by ja baudin View Post
    First I drilled the holes through the mounts and then through the top. Used a countersink bit on the table top followed by using a flat head (countersink) bolt.
    Thanks for the comments, thanks for the advice too Monte.
    So basically you drilled the holes through the mounts and table so the bolt would go through and then using your coutersink bit, you drilled it in just deep enough to get the head of the bolt flush with the table?
    How much table thickness was left after you used the countersink bit?
    Where can I find "flat head" (countersink) bolts?
    Can you post a pic of your countersink bit? Whats the difference in just using a bit the size of the bolt head to get it flush with the table?
    I really like this idea since it allows almost any plate to be made flat. And changing out the plate would never be an issue (no welds to grind).
  3. #33
    Dec 2012
    Sweetwater, TX
    201
    Also what size (ft x ft) table top did you settle on?
    Can you post a link to where you found your casters at?
    Thanks!
  4. #34
    Dec 2011
    406
    Clint
    I've never had the pleasure of shopping in a Texas hardware store but I would assume they are not so different from hardware stores here. Most any of them should be able to supply you with "countersink bolts" aka "flat head stove bolts" and if you think you need something stronger "flat head Allen Cap screws". The later is available in fine or coarse thread and are much stronger than stove bolts but I don't think a table top will really put much strain on the bolts unless you run into the table with the forklift.
    You can use a drill bit as large or larger than the maximum diameter of the bolt to countersink the heads in but it is advisable to match the taper on the drill bit cutting edge to the taper under the bolt head so the head will seat properly. A drill bit may also be more inclined to chatter but it certainly can be done. The plate thickness at the outer diameter of the head will be close to the total thickness of the plate and in that application it is probably more likely to snap the heads off the bolts than to pull them though the plate.
    I suppose you could also use pan head screws and a flat bottom milling cutter with a guide but the plate in the bottom of the hole would only be what's left after you account for the head thickness.
    Meltedmetal
  5. #35
    Mar 2011
    La
    273
    Table is 4x4, casters found at Tractor Supply. Thanks for the explanation Meltedmetal. Ja
    Dynasty 200 DX
    Diversion 180 (sold)
    Millermatic 350P, XR-Aluma-Pro
    30A Spoolgun
    Lincoln Pro Mig 140
    Hypertherm Powermax 30
    14" Rage Evolution 360
    40 ton press brake
    Shop full of tools
