Results 1 to 10 of 19
    Aug 2012
    Hermiston Oregon
    286
    Default Moving out the garage into a shop?
    I'm being offered a small shop about the same size as a 2 car garage at my go to mechanics shop. Its hidden behind his building. He's asking 500 with all utilities included.
    CONS: HAS ONLY A MAN DOOR 36" WIDE.
    ITS HIDDEN NO STREET VIEW.
    RURAL SETTING. 2 MILES OUT OF CITY.
    PROS: LARGE PARKING LOT.
    HEATER FOR THE WINTER MONTHS.
    LOTS OF TRAFFIC ON HIGHWAY UP FRONT.
    with the winter months around the corner. And work slowing down I have my doubts.
    Most all my income comes from truckers
    Repairing frames & aluminum fuel tanks.
    Edit: As of now I'm only mobile. A shop setting would be good change. Having work come to me instead of me chasing it all over town.
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
    Apr 2009
    147
    dang, that 36" door sounds like a deal breaker. for that square footage and no door to speak of, $500 doesn't sounds like that sweet of a deal.
    5x10 Bluco Fixture Table
    Cincinnati shear 10'x1/4"
    '11 Lincoln Power Mig 216
    '10 Syncro200 TIG runner
    Scotchman CPO 350 LT cold saw w/ AMS
    Aug 2012
    Hermiston Oregon
    286
    Default shop
    Here's a picture of the lot there's a large concrete pat in front if the shop. Maybe
    20'x40'. I could build a carport?
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    Oct 2006
    Illinois
    651
    What is your location ? What kind of power does it have ? What kind of heat ?
    Is there a bathroom ? Any other places available with overhead door or doors ?
    What someone ask and what he gets are two different things. Sounds like outside work on trucks is gonna be cold . What would he say about trucks being parked or stored in back ? Maybe you could rent it with the rear parking lot and rent truck trailer parking to offset the 500.00 ? I would look around and check craigs list.
    Aug 2012
    Hermiston Oregon
    286
    Quote Originally Posted by BD1:292195
    Its Hermiston Oregon
    220v & 120v
    Heat is from an oil stove
    Yes theres a full bathroom
    with shower stall.
    Hermiston is in a farming setting
    Theres two major freeways. 182 & 84
    I've looked at possible shop. And are either around 2k monthly. Or for sale.
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    Dec 2011
    Ray City GA
    14
    Would the owner be mad if you installed a roll up door?
    Aug 2012
    Hermiston Oregon
    286
    I plan on asking. On a roll up door. Like the ones found on metal sheds or self storages.
    Theres one for sale near here at 350 obo. Its a 10x8 self contained roll up. I'd would just need to frame it in. Would I cover the cost of the roll up and installation. Or could I maybe get it deducted from rent how's that work.
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    Oct 2006
    Illinois
    651
    Oregon ! sorry,that's out of my area. Cutting a door in sounds better if you can deal on it. Would you be able to have a storage trailer out there ? That may help
    work things out if you need to free up floor space. Sounds like all you need is a microwave and you can move in. Might be a home away from home; if the wife girl friend throws you out. I'm looking forward to the postings. Good luck
    northern NJ
    1,919
    Have you checked the zoning in this town? Is this property zoned for light industrial? Maybe it doesn't matter where you are but I would check before you make a deal to move in. Don't forget you will need insurance also. Any truck work will be outside on the slab. A two car garage gets full real quick but it would be a start.
    Will your customers want to bring you work instead of you going to them? How much of your work now would actually fit in the shop as apposed to doing it outside on the pad?
    MM250
    RCCS-14
    Aug 2012
    Hermiston Oregon
    286
    Yes there's enough parking room out there. I could fit 3-5 trailers if I had to.
    I'm going to be speaking with the owner tomorrow. On lowering the rent & putting in a larger door. Other than being hidden. Its not a bad spot just outside city limits.
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
