Results 1 to 10 of 12
    May 2006
    Kansas City Missouri
    84
    Angry Rotating welding device
    Anyone have plains or has constructed a rotating welding table for welding round tubing. I have seen the fixtures advertised but they are very expensive. I have electric motors but getting the speed to gear down in my problem.
    3,648
    Well gearhead you need a gearbox to slow it down. Check ebay and do a google search they are cheap on the web. I got a NIB 60 to 1 for 100 bucks its 600 local. I have a home made positioner that i use the base for a few other items i just switch the tops. It works great...Bob
    May 2006
    84
    So 60 to 1 is the gear ratio I should be looking for. I'll do the searching. thanks
    3,648
    Here is my gearbox setup for bending metal, the gearbox fits many machines i have i just remove 3 bolts and the whole unit removes to bolt on another machine. The pic with the top removed is what you want. Add another top, and a shaft with a plwyood top and you are ready to go. You can even cover the plywood with sheetmetal to keep it from burning. Also 60-1 is the slowest i found reasonable...Bob
    http://pg.photos.yahoo.com/ph/aameta.../ph//my_photos
    100
    You'll probably want to consider a variable speed motor so you can match your welding speed. Most of these units have a foot pedal or dial for this.
    May 2006
    84
    Why couldn't I just use an electrical reastat (sp) switch on the motor to change the speed.
    100
    You can if your motor is wired for it. I don't know how to tell, but someone here probably does.
    Jan 2009
    Coatesville Indiana
    4
    i cant get your link for the pic to work. did i read in hear not to long ago about using a tred mill motor/
    Jason
    PA
    286
    Default welding turntable
    Hello gearhead,
    Here are some photos of a turntable I made. It uses a gear reducer I had sitting for 20 some years. Ratio is 1725 to 1 so I had to do some experimenting.
    I first put a 3" diameter pipe coupling on an old record player and had a friend turn it slowly at rough tig welding speed while I timed it with a stopwatch.
    We came up with 1/2 to 3 RPM as a range for the turntable speed for my needs. Your needs (and mileage) may vary.
    Then I ran the numbers with my existing gear reducer and found a 12 volt DC motor on ebay.
    It works perfectly as far as speed range for the turntable as I can use 12 to 24 volts DC to run it.
    The nice thing is that by swapping the leads (it has only 2), the motor will also reverse rotation. This is a nice plus.
    I got the motor couplings from Reid Tool (www.reidtool.com) and the 3 jaw chuck from ebay.
    I found the motor speed control in the internet and SSC controls (www.ssccontrols.com) has a foot switch and resistor which works for my set-up very similar to a tig foot control. SSC Controls will
    change the resistor value to match your needs. They also make TIG foot controls.
    Welded a plate to the motor coupling in case I had odd shaped pieces to weld.
    Most welding is done with the 3 jaw chuck.
    Hard part is using both feet and not mixing up who does what.
    Hope the photos help.
    Vernon Ct
    117
    I made this one for me and it works good. It's a dc motor with a 300 to 1 gear box. The max rpm is 6 and it's a little fast for big diameters. The motor and gear box are ebay stuff.
    As you can see I use it for other things. I had to roll 1/4 x 1 hast x. I did 1 by hand and figured there was a better way. There was!
    I had to build something bigger than my little Atlas before I killed it.
    Mike
    MD Welding & Fabricating L.L.C.
    mdwelding@sbcglobal.net
