Results 11 to 18 of 18
    Jun 2012
    12
    Ya, thats what my google search found. I was dumbfounded when I read it.
    May 2009
    Central North Carolina
    149
    Ok, according to that, welding galvanized steel won't kill you. It will just make you so sick that you will think that you are dying. Well, that's how I felt when I got into it, and it lasted 3 days for me. The only way I will touch galvanize again is if I'm wearing the proper filtered mask and there is a slight breeze to take the smoke away from me. Even after grinding it off there always seems to be some left behind in/on the steel to smoke and pop at you.
    Charley
    ______________________________
    Miller MM252
    Miller Bobcat 225NT
    2 O/A torch sets
    Milwaukee 8" Dry Cut Saw
    Milwaukee 9" Grinder
    2 Milwaukee 4 1/2" Grinders
    Wallace 5 Ton Gantry
    Too many hand tools
    asheville n.c.
    618
    if you have to weld it drink coffee or tea to wash it out. my dad taught me that one and it works for me
    wisconsin
    116
    In the late seventies they just told us to drink alot of milk before you welded it.It is supose to keep you from getting sick.
    Sep 2012
    seaford de
    406
    I can tell u this for sure.. anytime u burn through galvanized it definetly affects the welds integrity. It may not matter a whole lot on sheet metal when your welding the corners but when your welding structural steel with 7018 and you dont get all the galv off the weld area and an inch past it your weld will fail xray and possibly a bend test too
    asheville n.c.
    618
    Quote Originally Posted by weldonwelding View Post
    havent had that issue yet. i burn it out with 6010 then 7018 or i use 232 innershield and burn right thru it. just completed a job with a bunch of galvanized. i welded every piece on the job and it all passed. of course the flat welding was hardest but i cranked 30 volts into the flat with .072 232. probably 175 ipm or more
    Sep 2012
    seaford de
    406
    Passed what? Jus a visual.... it may look ok but it is still contaminated
    asheville n.c.
    618
    U.t.
