Results 1 to 7 of 7
    Sep 2012
    2
    Default Woodworker needs some help
    Guys, looking for some advice.
    I have the need for attaching 3/16" and 1/4" diameter sst rod in a grid pattern. Looking for a fast and reliable means to do this. With my limited knowledge of welding, it seems like if I could rig up the tips of a spot welder to have good contact on these rounds, and I could get good force to these tips, I could spot weld these joints.
    Any thoughts or am I way off base with this idea?
    Salem ,Ohio
    3,647
    Cool
    Don't know what size spot welder you have but you may be under powered....Bob
    Sep 2012
    2
    Thanks Bob for the reply, but I don't have a spot welder yet. I'm just trying to get input on if a spot welder could do the job, what size I need and if two steel rods at 90 degrees have enough contact area for a spot welder to work....?
    WY...armpit of U.S.A.
    636
    Your typical spot welder, even the 220v variety, isn't going to give you the penetration necessary for your job. About the best you could hope for would be a bond similar to that a tube of JB Weld.
    I believe that if you click on the link below you'll see that the maximum capacity of a Miller 220v spot welder is 3/16". That is 3/16" TOTAL thickness for both parts added together.
    If you wish to go cheap...stick welder, easy...MIG welder and precision (but far from inexpensive)...TIG welder.
    http://www.millerwelds.com/products/spotwelders/
    Miller DialArc 250
    Lincoln PrecisionTig 275
    Hypertherm 900 plasma cutter
    Jet 14 X 40 lathe...ditto
    Logan 7" shaper
    Ellis 3000 band saw
    Lots of dust bunnies
    PA
    286
    whillyjo,
    Did a real quick and dirty test with my Miller LMSW-52 on 1/4" diam stainless rod.
    Pieces are about 3" long.
    Tried to get good close up photos but the depth of field suffers the closer I got.
    Anyway, one spot weld like this is easy. Took about 1 second.
    Drawback is that you get burn marks on the outside surfaces.
    I was sloppy so it may be better with practice.
    Trade-off is that a cleaner looking short dwell time spot weld may not be as strong as a longer one.
    My LMSW-52 has 12" tongs which reduces the amperage at the tips but I had more than enough power.
    If I had held the switch down longer, I would have melted both rods.
    Stainless has higher electrical resistance than carbon steel so this may make a slight difference.
    I think the hardest part may to align your pieces and to hold them securely between the spot welder tips.
    May require machining a special set so they won't slip.
    Anyway, hope this helps.
    http://www.millerwelds.com/products/...__air-cooled_/
    Los Angeles
    2,634
    maybe you can find something that will work for you
    http://www.twpinc.com/wire-mesh/TWPCAT_5
    Ed Conley
    MM252
    MM211
    Passport Plus w/Spool Gun
    TA185
    Miller 125c Plasma 120v
    O/A set
    SO 2020 Bender
    You can call me Bacchus
    Sep 2011
    7
    I would go this route too. you can also try mc nickels also
