Results 1 to 10 of 10
    3,945
    Cool Pocket size layout guide for holes.
    I do lots of hole layout at work in steel pipes and i can remember the holes sizes but i can't set my dividers from memory. So i like everyone else hold my dividers up to a tape measure or use a rule to set them. Then i made this aluminum plate with a center and the rest of the hole sizes layed out in a semi circle. So now i just stick one leg of the dividers in the center punch mark and the other leg in the size i want. Simple enough. Sure knocked off a bunch of time when you have to layout 25 holes all different sizes. I even have room for sizes i might run across sometime Standard size fittings on the right and 3000# fittings on the left...Bob
    Nov 2008
    181
    excellent idea!
    Professional firefighter (retired). Amateur everything else I try to do...
    Oh yeah: GO BIG RED!
    May 2012
    215
    Default Pocket size layout guide for holes.
    Nice.... Except for the decimals
    alabama
    750
    Nice, but a few questions.
    1) why not just use a strait line for each length?
    2) seems to be a large jump in space from the 1" to 1.5" verses the 1.5" to 2"
    3) no 3" ?
    2, XMT's 350 cc/cv
    1, BOBCAT 250
    1, TRAILBLAZER 302
    1, MILLER DVI
    1, PASSPORT PLUS
    1, DYNASTY 200 DX
    1, MAXSTAR 150 STL
    1, HOBART CHAMP
    1, HF-251 BOX
    1, S-74d
    1, S-75DXA
    2, 12-RC SUITCASES
    2, 30 A spoolguns
    3,945
    Quote Originally Posted by fabricator View Post
    3) no 3" ?
    Straight would work.
    Don't know about the jump as those are the OD's of the couplings i use.
    I don't use a 3" coupling and the size could be added but our shop didn't have one laying around to measure...Bob
    Rosetown, SK.
    519
    Excellent idea Bob. Thanks for sharing. Will be making one for our shop
    252 Miller Mig
    180 Synchrowave
    R - 45 Milling Machine
    Kingston 1100 Lathe
    Miller 2050 Plasma Cutter
    Aug 2012
    23
    good idea, now I know what I'll build next time I'm waiting on parts
    Apr 2011
    367
    3) no 3" ?
    I think the #s on the right are correct but the #s on the left seem to be messed up...FWICT
    Just For Home Projects.
    3,945
    Quote Originally Posted by Doughboyracer View Post
    The left side is for 3,000# couplings are both sides are correct to the fittings. There is a line for 2" pipe on the right side as its the only size of pipe i use so i put it there. I make special tanks and pressure vessels and these are the sizes i use. More can be added at any time...Bob
    Apr 2011
    367
    I get it now...thanks.
    It would have helped to read the post not just look at the pictures...
