Results 1 to 8 of 8
    Aug 2012
    3
    Default I am looking for tips on out of position welding of 16ga stainless.
    I am using .023 stainless wire with 75/25% argon /co2 mix. Starts real cold with a lot of spatter and no penetration , then seams to heat up and weld nice but will still go cold mid weld seamingly for no reason. Am I using the right stuff? Is my little 110v mig not running properly?
    Aug 2011
    Banning,Ca
    3
    Polarity?
    Aug 2011
    Banning,Ca
    3
    Previously using flux ? Maybe it's the polarity
    Aug 2012
    3
    Stinger positive? Bad ground maybe? I'm thinking I will tighten the drive rolls and change out the liner. I never have a problem with steel wire just the Ss wire .
    Feb 2012
    Wa
    531
    Have you tried using tri gas blend?
    Aug 2012
    3
    Just picked up a bottle of helium90% , argon 7.5% and co2 2.5% . Going to give that a try. Should I reverse the polarity? I have the welder set up as DC+. I also noticed that the 16gauge stainless duct that came from the factory is welded using 035 Ss wire but there is hardly any penetration on the factory welds. Should I up size my wire from 023?
    Feb 2012
    Wa
    531
    .023 should be fine. polarity should be the same as mild steel mig.
    Jun 2012
    McHenry, Il
    23
    Default Miller MIG Calculator 18 & 16 ga. SS
    Hope this helps
    Jim
