Results 1 to 10 of 19
Thread: Need Red Parts
    Sep 2008
    11
    Default Need Red Parts
    As usual the red forum is no help so I'll try here. Got an old sp-200 wire machine and need a drive motor. Can't see paying $400 for it from red and comp that made motor has folded and I can't find any specs.
    Info I have from motor is
    Jones Instruments
    Stamford Ct
    Motak
    12v
    # P1020-103
    If I could find motor specs I could cross reference and adapt something.
    Lincoln # S16952-1
    Thanks in advance
    Dave
    Dave Notarianni
    Cranston RI
    Dilligaf@uri.edu
    Try giving Grainger a call. They can cross reference and match just about any electric motor.
    Chances are that motor is "off the shelf" and wasn't designed and made specifically for Lincoln. Relays, switches and contactors are the same way and have many applications.
    Sep 2008
    11
    Just got off phone with Grainger They have no cross reference but can match something if I can get specs
    Dave
    Dave Notarianni
    Cranston RI
    Dilligaf@uri.edu
    8,096
    Well $400 is actually a good deal, as my cost is $368
    Sep 2008
    11
    Before I buy a 400 motor I would prefer a 100 motor and also want to make sure the board that drives it is OK. I'll gamble with 100 but not 400 on a 1980s machine
    Dave
    Dave Notarianni
    Cranston RI
    Dilligaf@uri.edu
    8,096
    The problem usually is with the gear box, not the drive motor.
    Sep 2008
    11
    In playing with it today I have to wonder if the drive is the problem or a result. Electronics guy helping me out was checking voltage and amp draw and we found there was AC present in the DC motor feed lines. Starting to look like a control board problem. Any other ideas cruiser? There is some wear in the drive gears and if it needs a board also I think it will be time for a replacment machine
    Dave
    Dave Notarianni
    Cranston RI
    Dilligaf@uri.edu
    8,096
    As your electrician will know, that AC your reading is merely a ghost signal. Electricians and electronics don't mix well together
    Sep 2008
    11
    I can agree with the mixing but would I still see a ghost with the motor out of the equation and using a load to replicate the drive motor? Sad part is the motor and drive seem to run fine when connected up to a separate power supply. Wire feeds smooth and easy with no drag thru the liner.
    questions and more questions but no clear answers
    Dave
    Dave Notarianni
    Cranston RI
    Dilligaf@uri.edu
    8,096
    is the 10 amp fuse on the circuit board blown?
    Do you have arc voltage?
    Is there a timer kit installed?
    Has the 2.5 amp motor circuit breaker tripped?
    If you were to jumper the trigger leads at your machine, does the motor turn?
    Questions that need to be answered....
