The following are several pics of some welding projects I recently completed. I am largely self taught with the most time on MIG welding. TIG and Stick have only been recently.
These were all done with metal I scrounged or had on hand.
The first is a torch stand (made from stainless that was TIG welded).....It accomdates Stick, MIG and TIG torches.
Results 1 to 4 of 4
07-18-2012, 07:32 PM #1
Member
- May 2010
- 55
Some Welding Projects....Looking For Opinions !!!
07-19-2012, 06:20 AM #2
I suggest you do not hang your tig torch by the cup and I also suggest you change the angle so the weight of the lead is not pulling on the torch as it is now. Too much stress at than angle in my opinion.
Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
07-19-2012, 07:38 AM #3
- Oct 2006
- Illinois
- 459
I agree with monte. You might be able to cut out some of flat washer on the side so the narrow part of torch will slide in.
07-19-2012, 12:49 PM #4
I made a tig torch holder with a magnetic base and is adjustable . It's in the "projects" part of the forum. It holds the torch not creating any strain on it.
Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
2-O/A outfits
Jet Lathe and Mill
Propane Forge
