Results 1 to 10 of 12
    Default Built a new stand for my Bandsaw
    Here's a couple of pics of the Bandsaw stand I just finished. I know it is not much different than what some others have put together. Other mods to the saw can also be seen in the pics. Oh, and I added a pic of my heavy duty beer holder too.
    Larry
    "I feel for the man who can only spell a word one way"......Mark Twain
    Lincoln AC225-S (OLD/Copper Wound)
    Lincoln Weldpac 100
    Miller Matic 180 (auto set)
    Miller Spool gun 100
    Miller Spectrum 375 Extreme
    Victor Super Range II
    May 2008
    Fredericton, NB Canada
    124
    Looks pretty slick.
    I have a question now that I am looking at the coolant feed system though - do these bandsaws "flick" much coolant around when they are running? If my metal hobby tasks continue to expand I might consider getting one of these as an alternate to the chopsaws that fling sparks and debris all over the place....
    If you notice my saw is mounted in a drip pan with a drain back to the recirculating pump. Both the pan and the saw are 26 inches long, I should have made the 28. It can be quite messy with coolant following the blade off the ends of the pan if you do not keep the flow of coolant down. I open the ball valve just enough to get a small stream of coolant flowing over the blade just before the cut, this seems to keep the heat under control and reportedly extends blade life. Also a blade wiper located just after the stock helps keep the coolant under control. The reason I am using the magnetic mounted coolant nozzle is that I can also use it on the drill press when needed.
    The saws run slow so they do not "fling" much of anything off the blade very far. Much quieter and cleaner than a chop saw. Even cleaner if you choose not to use coolant, bu with water soluble oil as coolant, any splashes or spills are a small matter. I would never use an abrasive chop saw in my garage but use the badsaw often.
    The taller stand allows me to use my pipe stands as in feed and out feed supports. The factory stand places the cutting table/vise at slightly less than 24" from the floor.
    Larry
    Lincoln Weldpac 100
    Dec 2008
    CDB Land, TN
    135
    Nice looking rig ya got there.
    Did you add the assist cylinder?
    Be safe
    Jeff
    Give more than you get and
    you will get more than ya need.
    This is true for the good and bad
    that life puts out.
    what brand is that saw?!?!?!?
    is that a harborfrieght? if so how do you like it? they are on a wicked sale right now and was thinking about picking one up
    Wow, that's a great band saw set up. I want one. Did you add the coolant system?
    But, more important, that beer holders is genius - you even got rings on it to stabilize the beverage consumer. Now if you could connect some of that band saw coolant tubing to keep that beer cool, you'd have the perfect stand. I'm making some of these...
    Good job on both!
    MTBob
    ____________________________
    MM 251 w/Spool gun
    MM 135
    Evolution Cut Off saw
    Logan Lathe
    Clausing Mill
    Walker Turner Drill Press
    Thanks for the replies.
    The hydraulic downfeed control is actually a pneumatic door closer, drilled, taped and filled with hydraulic fluid. The flow is controlled by a needle valve from an ice maker install kit. Yes it works but is not sealed at the top so the saw head must be raised slowly to the vertical position to avoid spilling hydraulic fluid out the top of the cylinder. Maybe a little problematic but not so much so as to make it worth the money to take the plunge for a "real" cylinder. This was not my idea. But I may be the only one who decided to go ahead with it, not having a lathe to make a proper sealed plug for the top of the cylinder. Works good enough for home shop use as far as I am concerned.
    The coolant pump is another Harbor Freight item. I decided to stay with the magnetic coolant nozzle because that way I can also use it on the drill press when needed.
    It is the current 4x6 banadsaw that Harbor Freight sells. I built the stand tall enough to work with my pipe stands. A major improvement over the little stand that came with the saw. In fact of all the modifications (improvements?) I have made to the saw, getting it up off the ground is the most useful.
    Larry
    Lincoln Weldpac 100
    Mar 2008
    148
    I just love the ingenuity! Great idea!
    RoyB
    Dartmouth, MA
    http://www.rvbprecision.com
    Millermatic 185 MIG
    Miller Diversion 165
    Purox W200 O/A
    Grizzly 9957 Mill
    Grizzly 4030 Metal Band Saw
    Grizzly 1050 Knife Belt Sander
    Jet 1236 Metal Lathe
    TP Blast Cabinet
    Apr 2006
    San Diego
    375
    Thumbs up
    Nice work, Larry.
    All of your projects come out nice and tidy.
    I have an older Ellis 1000 that I need to raise up to make it more user friendly. I don't think I'll add a coolant pump, but it needs a better stand nonetheless.
    Maxstar 200DX
    Maxstar 300DX
    Passport
    Spectrum 701
    LMSW-52 spot welder
    Austin, TX
    621
    Awesome setup there. Cool idea with the mods.
    How is the accuracy on that bandsaw? I had a chinese knock-off mitering bandsaw that I was sorely disappointed with. It had a 1/2" blade. I bet with the coolant it makes a difference on the accuracy.
    I like the idea of having something I can use in the garage, as opposed to having to setup my dry cut carbide saw outside that spews sparks and metal shavings everywhere.
    Miller Maxstar 200 DX
    RMLS-14 Momentary Hand Control
    Miller Syncrowave 180 SD
    Porter Cable 14" dry metal saw
    Hitachi 4.5" grinder
    http://mhayesdesign.com
